verifying DZ 302 - Team Camaro Tech
post #1 of 4 (permalink) Old Dec 21st, 18, 01:54 PM Thread Starter
Probationer
Dan
Question verifying DZ 302
I have a 69 Z-28 that I bought in 1987 from a friend. I was told at the time that it was the orginal motor but it had different heards and intake. It had be rebuilt with a different intake, carb, heads and cam. The motor had been decked before and I cannot see all of the numbers. The casting number is 3970010. The serial number on the front of the block that I can make out is CEOA487.
Can anyone help me determine if this is the orginal 302? I am also not sure what heads are on it. They are a double hump 202 head with the casting number of 3782461.
Thanks for any help anyone can provide.
Gochevypower is offline
post #2 of 4 (permalink) Old Dec 21st, 18, 02:09 PM
Andrew
Andrew69's Avatar
Re: verifying DZ 302
I believe the CE is Counter Exchange, a replacement engine probably replaced under warranty. So not the original engine to the car.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #3 of 4 (permalink) Old Dec 21st, 18, 02:30 PM
keith
X-77 keith's Avatar
Andrew is correct. It is a replacement engine. Over on the Chevelle site I was told "CE" stood for Chevrolet Engine. I have always called it counter exchange as well. I didn't argue it, because we all know what the engine is. The heads should have accessory holes. They look a lot like a 305 casting , except the humps are larger. Sorry the engine is not original to the car.
X-77 keith
X-77 keith is offline
post #4 of 4 (permalink) Old Dec 21st, 18, 04:44 PM
Chick
68camaroz28's Avatar
Welcome aboard Dan,
Here is a current thread on the CRG discussing warranty replacement blocks as you have.
CE motor stamping info
Chick
68, 69, & 2015 Z/28's
69 Nova's L34 Father/Son & L78 Surv purch-new
67, 68, & 2015 Z06 Corvettes
Our 68Z Restoration
68camaroz28 is offline
