Periodic starter grind - Team Camaro Tech
 2Likes
  • 1 Post By 4Speed67CamaroRS
  • 1 Post By ZEN357
post #1 of 7 (permalink) Old Dec 28th, 18, 08:29 AM Thread Starter
Hi,
Does/did anyone have an issue like this? I purchased this starter https://www.summitracing.com/parts/PWM-9100 for my bbc and it has no issue turning over the motor but half the time, it doesn't engage properly and grinds against the flywheel. I've used no shims up to four shims in an effort to correct this issue with no luck. I had purchased the starter over a year prior to getting the car running and thought maybe it was the starter but the warranty was only for a year so I purchased another but no difference. This starter says good for 168 or 153 tooth flywheels. I don't quite understand that but apparently it has to do with different diameter flywheels. I now have this starter coming https://www.summitracing.com/parts/pwm-9526 which only states 168 tooth flywheels in hopes that it will consistently engage properly cure my issue. Aside from the damage it's doing frankly it's embarrassing!
Thanks, Jim
No School Like The Old School!
67 RS 4 Speed with Big Block conversion
12 bolt with Richmond 3.90's
4Speed67CamaroRS is offline
post #2 of 7 (permalink) Old Dec 28th, 18, 08:53 AM
Rick
Re: Periodic starter grind
The last time that happened to me it turned out that one of the starter bolts loosened up a bit. I figured that the torque of the starter would throw off the alignment and some times it would catch properly and some times it wouldn't. Also check the new bolts that came with the starter. Cheep bolts may not be sized correctly. The knurl is supposed to keep the bolt shaft snug in the starter bolt holes so the torque of the starter does not have that little movement that throws off the alignment.
Rick
Sam 15 is offline
post #3 of 7 (permalink) Old Dec 28th, 18, 01:17 PM
Jim, This thread discusses how to check starter clearance and shimming. Alignment,
rigidity/support are very important. You can't just replace the starter without checking
the alignment, etc. I doubt there's anything wrong with the first starter you used.
https://www.camaros.net/forums/19-el...-question.html
Here's an article you may also find helpful .
https://www.chevyhardcore.com/news/c...all-situation/
my 67' build thread:
allanjs is offline
post #4 of 7 (permalink) Old Dec 28th, 18, 01:48 PM Thread Starter
Thanks a bunch. I guess I should look at the starter bolts a bit closer. Can you tell me the correct (hopefully easy) way to manually engage the starter?
I'll look into what I have before opening the box of the starter on order.
Thanks, Jim
post #5 of 7 (permalink) Old Dec 28th, 18, 04:33 PM
Thanks, Jim
Jim, This will help.
Chevy Starter Tuning - Super Chevy Magazine
allanjs is offline
post #6 of 7 (permalink) Old Jan 2nd, 19, 10:10 PM Thread Starter
Thanks, Jim
So after finally having a day off to look at the starter issue the result was, no matter how I lined up or shimmed the starter that I have on the car https://www.summitracing.com/parts/PWM-9100, the same thing kept happening. I took the starter off and compared it to the new one (more expensive one) https://www.summitracing.com/parts/pwm-9526 that I had just bought, and I could see the quality difference. The first thing was the pinion gear was actually bigger than the cheaper starter. I had read that the pinions gears are the same for 153 tooth and 168 tooth. It's the flywheel size that makes them both work. Whether that is the case or not, the more expensive one definitely has a bigger pinion gear and only lists it fitting the 168 tooth flywheel.
Ultimately I installed the new starter with no shims and it starts beautifully. Hopefully that continues the be the case. So far so good. If it turns out this didn't solve the issue, I'll let you know.
Thanks, Jim
allanjs likes this.
post #7 of 7 (permalink) Old Jan 3rd, 19, 05:32 AM
Ed
I had the same issue with my 66 Big Block Vette. I think I bought three starters before I found the correct one and got it shimmed properly before I had no grinding noise.
4Speed67CamaroRS likes this.
ZEN357 is offline
