Hei distributor no spark - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 31st, 18, 12:15 PM Thread Starter
LP
Probationer
Larry
I have a 2007 350 crate engine 330 HP model with HEI ignition, not getting spark to the plugs. A few years back I had the similar problem and replaced the module. I've read a few articles on how to check some of the other parts of the system,ie,coil, pick up etc. How long does a module usually last if it is indeed the problem. Any thoughts would be appreciated.
LP is offline
post #2 of 5 (permalink) Old Dec 31st, 18, 01:41 PM
kevin
Re: Hei distributor no spark
sometimes like a light bulb . new today bad 2 hours later
flat tire is online now
post #3 of 5 (permalink) Old Dec 31st, 18, 02:22 PM
Be sure the wires are connected and triple check your ground.
68 Camaro~LSx ~all motor
post #4 of 5 (permalink) Old Dec 31st, 18, 03:21 PM Thread Starter
LP
Probationer
Larry
LP is offline
post #5 of 5 (permalink) Old Dec 31st, 18, 04:28 PM
Meant to say connected correctly...
