Small block chevy head gaskets - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 8th, 19, 08:30 AM Thread Starter
keith
X-77 keith's Avatar
I am building a mild 350 with steel heads. Maybe 350 horse. Has anyone had any experience with Felpro PermaTorqueSD 501 gaskets? Good , bad, or any info would be appreciated. I have used the old blue felpro's for years, just wondering if these at as good or better. Thanks Keith
ID:	223879   Click image for larger version
X-77 keith
X-77 keith is offline
post #2 of 6 (permalink) Old Jan 8th, 19, 09:31 AM
Re: Small block chevy head gaskets
Fel-Pro is as good as it gets for the street (you don't need multiple layer steel gaskets unless boosted or have race gas compression ratios).
Two things to specifying a gasket and those are compressed thicknes to set your quench and bore diameter (can not enter the bore but excess size decreases compression ratio).
big Dave
Larger Dave is offline
post #3 of 6 (permalink) Old Jan 8th, 19, 01:51 PM Thread Starter
keith
X-77 keith's Avatar
Thanks Dave. I trust FELPRO, just never seen these black gaskets before. I have always used the pail blue ones. I ran out of the blue ones. The car owner brought these to me. I was just wondering if they are safe. Thanks.
X-77 keith
post #4 of 6 (permalink) Old Feb 13th, 19, 02:18 PM Thread Starter
keith
X-77 keith's Avatar
Update. ...
I installed the heads on the engine. The heads are 69 double humps with the bolt holes. Had the heads worked ,surfaced, and checked for cracks. There was nothing wrong with the engine prior to the head swap. It had edelbrock proformer heads on it. The guy wanted a more stock look. I torqued the new ARP bolts in a series of three torques. 25, 45, and then 65. Ran the engine for about 10 minutes. Ran great. Looked under and antifreeze is dripping on the drivers side near the dipstick. Head has to come back off. It will go back to the machine shop to be checked again. First head gasket issue I have ever had.
X-77 keith
post #5 of 6 (permalink) Old Feb 13th, 19, 04:44 PM
Andrew
Andrew69's Avatar
😡 Hope your 2nd go is successful.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #6 of 6 (permalink) Old Feb 13th, 19, 05:09 PM Thread Starter
keith
X-77 keith's Avatar
Thanks. I guess that is what I get for using a head gasket that I am not familiar with. Just moved the car over to an empty bay and walked away. That was 2 weeks ago.
X-77 keith
