427 SBC or 496 BBC - Team Camaro Tech
 1Likes
  • 1 Post By Larger Dave
post #1 of 12 (permalink) Old Jan 11th, 19, 07:26 PM Thread Starter
427 SBC or 496 BBC
Looking to make a change from my 388. I have been looking at a 427 sbc making about 652 hp or a 496 bbc making about 600 hp. Both about the same price. I know there will be some expense moving to the bbc but not too worried about that.
I'm torn on which way to go. The car is 90% street driven and want something different than my 388.
What would you do? Just looking for fun street car that is fast and turns heads.
67 Camaro with 388 with Edleborck RPM heads, Air Gap, CC 282S, Tremec TKO
LukeSkywalker is offline
post #2 of 12 (permalink) Old Jan 11th, 19, 08:03 PM
Re: 427 SBC or 496 BBC
Horsepower is wonderful if you are driving around the high bank of Dayton. On the street the 496 will make more torque which is what accelerates you. And this is one example of where the BBC may be cheaper to put together than the SBC.
https://www.speedwaymotors.com/BlueP...0aAlRVEALw_wcB
https://www.jegs.com/i/Blueprint-Eng...8aAjJVEALw_wcB
That said despite your willingness to swap from a small block over to a Huge block that will add to the costs and force changes over what you have now. I don't think a 496 is worth the investment in time, effort, and cash over a stout 427 SBC.
Big Dave
pittpens24 likes this.
Larger Dave is online now
post #3 of 12 (permalink) Old Jan 12th, 19, 04:56 AM
Travis
I went the 427 small block route and have no regrets. 535hp and 590tq. At 10:1 it runs great on pump gas and with 3:55s and a tko I get 20mpg cruising down the highway at 70.
Way different mileage when I'm beating on it
The only thing thats annoying is the people that say "you know thats a small block" when the hood is open.
Should have put 307 badging on it.
travisch is online now
post #4 of 12 (permalink) Old Jan 12th, 19, 05:25 AM
Greg
pittpens24's Avatar
I agree with Larger Dave. I went from a SBC to a BBC. What you have works and that is a huge plus right out of the gate. only thing you may want to look into upgrading is your radiator if your higher HP rating calls for it. Going BBC - you have no choice in the matter. Add to that a new pulley system, motor mounts, frame mounts, headers, manifold, carb, linkage, proper clutch bellcrank and linkage or hydraulic clutch set-up if going manual, bellhousing, starter, flywheel and dual disc clutch or flexplate, and driveshaft just off the top of my head. Parts add up quickly! And one last thing, you are already used to that high revving SBC, big blocks are all torque so it is a different feel and power. You will easily loose 1000 rpms on a built BBC from what you are already used to.
Although it was cheaper for me to build a stout 572 than a stout 427 - I lost on the other end where I had to literally replace everything including the trans and rear.
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #5 of 12 (permalink) Old Jan 12th, 19, 03:54 PM Thread Starter
Looks like 427 will be the way I go eventually. Going to get the suspension straightened out first and change the solid cam in my 388 to a Straub roller. I think that will get me the improvements I am looking for right now.
post #6 of 12 (permalink) Old Jan 12th, 19, 04:41 PM
Steve69SS396's Avatar
I went to a 427SBC 5 years ago and have been extremely happy. Bigblock power in a smaller lighter package.
Steve69SS396 is offline
post #7 of 12 (permalink) Old Jan 13th, 19, 07:42 AM
Brett
Steve, what is that pump on the left? Looks like a crank case purge? Surely that's not the Procharger that's in your sig. And I don't see an alternator?
As far as the OP, I think like the others, you would be happy staying with the SB...
Brett.....
Rockets Up In 2020!
Brettallen59 is offline
post #8 of 12 (permalink) Old Jan 13th, 19, 09:02 AM
Brett.....
Brett - That picture was before the Procharger. That is a vacuum pump on the left and the alternator is low on the right. Here's a picture with the Procharger.
post #9 of 12 (permalink) Old Jan 13th, 19, 11:38 AM
Brett
MMMMM...Nice Pic!
Brett.....
Rockets Up In 2020!
post #10 of 12 (permalink) Old Jan 13th, 19, 06:54 PM
1Slow64
496 is going to make more power easier than a sbc and less wear on internal components.
My 69 X66 project.
69X66 is offline
post #11 of 12 (permalink) Old Jan 13th, 19, 10:13 PM
N/A a larger engine like a 496 can make more power and torque than a 427SBC. It's all about displacement. Disagree on the wear piece. My engine currently makes about 1,000 at the flywheel. When it gets an intercooler I'll turn it up a little and make 1,300+. I've been driving the heck out of it on the street. Every 3-4 months I change the oil and cut the filter open. There has been no unusual wear. I plan on running my car in drag week in the next couple of years. You drive the car about 1,000 miles over 5 days and race it each day.
Here is a car that has been running drag week for several years with a turbo charged old school small block. It broke into the 7's this year.
post #12 of 12 (permalink) Old Jan 19th, 19, 03:42 PM
scott67ss396's Avatar
BBC all day I have a Blue print 496 love it, put the 396 in storage
1967 SS (496) BBC FiTech EFI
1972 454 Fitech EFI (Baldwin motion clone)
1978 Trans am Gold SE W72 (461)
scott67ss396 is offline
