69 chev bb motor mounts - Team Camaro Tech
 1Likes
  • 1 Post By Matt 69
post #1 of 5 (permalink) Old Jan 12th, 19, 09:19 AM Thread Starter
ken
Wink 69 chev bb motor mounts
I have 1969 chevy bb engine mark 4 and according to the threads a good way to prevent motor mounts from breaking lose is to use a solid motor mount on the drivers side. will the solid mount fit the standard bb chev frame mount. I have read various ways of changing the other passenger mount and also changing the trans mount. will I have to shim this also ? I found moroso solid motor mounts 62515 and 62510 will one of these work ? I have a loose motor mount on the drivers side now and would like to correct this problem. this camaro will be driven to car shows and weekend tours. the engine is a 427. thanks for looking camaro ken
ken5537 is offline
post #2 of 5 (permalink) Old Jan 12th, 19, 10:27 AM
scblucam's Avatar
Re: 69 chev bb motor mounts
Most modern motor mounts have a interlock? that will not let them separate if the rubber deteriorates. Back in the day it was two steel plates bonded to a rubber block. Separation could send you on a wild ride when the engine lifted applying more throttle. Solid mounts could tattle your teeth out depending on your engine.
68 302 M20 - 85 IROC Z
scblucam is offline
post #3 of 5 (permalink) Old Jan 12th, 19, 10:58 AM
Matt
There is no need to run solid motor mounts. Energy Suspension makes some nice motor mounts out of Polyurethane and they are very durable and interlock as well. I have had them on my car for over three years and my motor is putting out 500+ horsepower at the flywheel. No issue's at all and very smooth running as well.
Just 1 More likes this.
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is offline
post #4 of 5 (permalink) Old Jan 12th, 19, 01:53 PM Thread Starter
ken
Red face Re: 69 chev bb motor mounts
thanks for the info did you also change the trans mount to polyurethane ?
ken5537 is offline
post #5 of 5 (permalink) Old Jan 12th, 19, 04:03 PM
Matt
Yes. Equally as satisfied with their transmission mount as well.
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is offline
