69 camaro bb motor mounts - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 15th, 19, 11:55 AM Thread Starter
ken
Question 69 camaro bb motor mounts
I have to replace the motor mounts on my camaro I having a problem removing the bottom mounting bolt . the engine is in the car and the two top bolts are removed I read your threads but not much is covered about how to remove the bottom bolt that is in the bottom center of the mount I sure would appreciate some help on this problem. this is a bb chev engine thanks
ken5537 is offline
post #2 of 2 (permalink) Old Jan 15th, 19, 05:25 PM
Chick
68camaroz28's Avatar
Re: 69 camaro bb motor mounts
I'm reading as your replacing the mounts that have 3 bolts to the block. I have not done that but would think you could do one side at a time by taking the long main bolt of the engine mount to frame mount out and jacking the engine (cocking) to one side to be able to remove that bottom bolt, replacing the mount to block and then button that side up and then doing the other side. Many of us had to do that back in the day to put the drivers side header on. Just what I'm thinking that seems would work.
Chick
68, 69, & 2015 Z/28's
69 Nova's L34 Father/Son & L78 Surv purch-new
67, 68, & 2015 Z06 Corvettes
Our 68Z Restoration
68camaroz28 is offline
