Which LS3 Supercharger would you recommend - Team Camaro Tech
 1Likes
  • 1 Post By ttwo
post #1 of 10 (permalink) Old Jan 18th, 19, 03:15 PM Thread Starter
TJ
I have an LS3 480 in my 69. I put in over a year ago and once again I am looking for something else to add. I really would like to put on a supercharger. Anyone have opinion/suggestions on which brand to add that would be fairly clean, simple and looks good.
H20cooled likes this.
ttwo is offline
post #2 of 10 (permalink) Old Jan 18th, 19, 07:05 PM
Simon
Re: Which LS3 Supercharger would you recommend
They have a LS3 supercharger.
MAGNUSONPRODUCTS.COM
slazisme is offline
post #3 of 10 (permalink) Old Jan 18th, 19, 07:20 PM
I would look into an LSA supercharger but you are looking at a new accessory drive. You are definitely going down a rabbit hole....
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #4 of 10 (permalink) Old Jan 19th, 19, 06:38 AM
Maggie (about +100hp I guess 6psi with a pulley)
But you might out grow that quick too ?
BUT, there's always a turbo or 2, or a SC ?
Compression is going to be your limiting factor unless you run E85, a Meth kit, or the good gas....but there's still limits.
68 Camaro~LSx ~all motor
post #5 of 10 (permalink) Old Jan 19th, 19, 10:14 PM
Chris
stinger67's Avatar
[QUOTE=ttwo;1783113299]I have an LS3 480 in my 69. I put in over a year ago and once again I am looking for something else to add. I really would like to put on a supercharger. Anyone have opinion/suggestions on which brand to add that would be fairly clean, simple and looks good.
I'm looking into the same thing for my LS3/480. I have metal Stinger hood, so the inside is like a metal 2" cowl.
I have narrowed the choices down to the two Maggies or the LSA. It looks like both the front of the Maggie TVS2300 & the LSA plumbing hits the hood & I'd have to cut some structure. Not sure if that is a big deal. The Maggie Heartbeat looks to fit better as it has a lower throttle body.
My GM guy says LSA. My car parts guy says Maggie TSV2300 (cuz it looks bad ***)
If you go LSA look at https://boostdistrict.com/
If you have a fiberglass cowl, it looks like any of them would fit.
With the SC comes the decision of what new drive to buy. It sucks cuz I have a brand new Vintage Air drive system....ohhh well, its only money
stinger67 is offline
post #6 of 10 (permalink) Old Jan 19th, 19, 10:15 PM
Chris
stinger67's Avatar
[/IMG]
post #7 of 10 (permalink) Old Jan 20th, 19, 05:00 AM
A CTS-V LSA lid is lower profile and the hoses exit the rear. They can be bought used because a lot of guys swapped them out for the ZL1 lid.
dhutton is offline
post #8 of 10 (permalink) Old Jan 20th, 19, 07:58 AM Thread Starter
TJ
I'm not looking for more than maybe 150 or so HP extra. Will ALL of them require a new serpentine system?
ttwo is offline
post #9 of 10 (permalink) Old Jan 20th, 19, 10:24 AM
Chris
stinger67's Avatar
The LSA requires much less from what I am told. Boost District website seems to have a kit that includes an adapter that fits with your own pulley system, assuming your not already using an aftermarket pulley system. Like I said, I have a Vingage Air pulley system now and have been told to get a Vette pulley system if I go with the LSA.
post #10 of 10 (permalink) Old Jan 20th, 19, 11:51 AM
Pay close attention to the number of belt ribs and belt wrap on the pulleys. There is no point in a supercharger if the belt slips under load. Some systems do suffer from this due to poor design....
Advantage of a supercharger is a nice flat torque curve, not peak horsepower imho....
dhutton is offline
