Local early 350/350 score for the '67 - Team Camaro Tech
 3Likes
post #1 of 34 (permalink) Old Jan 20th, 19, 06:57 PM Thread Starter
Tim
I have been actively seeking a Chev 350 with a TH350 for my '67 RS Convertible
I'm ditching the PG and going to get a TH350 built for my future engine build (whatever that ends up)
I am going to install the TH350 and fix a bunch of other odds and ends, (heater core Replacement, getting factory A/C back online
adding my seat extenders and my factory Tilt column which I just sourced
Anyway, I scored a TH350 with a High nickel 4 bolt main block, 2482 on the center caps as (nodular iron 4 bolt caps GM used on heavy duty and performance engines)
out of a 72 truck standard bore never been apart, 300 bucks for both
ID:	224121   Click image for larger version
1967 RS/SS Coupe, Factory A/C, 2nd owner, original paint -Taho Turquoise 3 Spd on the floor, bench seat, fold down rear seat
1967 RS Convertible Factory A/C, PS, PB PG 327
Niblet is online now
post #2 of 34 (permalink) Old Jan 20th, 19, 07:03 PM
keith
X-77 keith's Avatar
Good score. I have had great results with the early 70's 350s. You might be able to get a few bucks for those ram horn manifolds.
X-77 keith
X-77 keith is offline
post #3 of 34 (permalink) Old Jan 20th, 19, 08:38 PM Thread Starter
Tim
Re: Local early 350/350 score for the '67
unfortunately both those manifolds were broke
post #4 of 34 (permalink) Old Jan 21st, 19, 12:34 AM
Send a message via AIM to hotrodbaker
Tim, did you say seat extenders? Your built ones or bought?
hotrodbaker is offline
post #5 of 34 (permalink) Old Jan 21st, 19, 02:59 AM Thread Starter
Tim
https://www.ebay.com/itm/1967-9-Camaro-Firebird-NEW-Seat-Track-Extenders-for-Xtra-4-of-legroom/233008590053?hash=item364064ece5:g:Jj0AAOxyuPtQ~xu 3:rk:2f:1&frcectupt=true
Any of the big name Camaro parts places sell them
post #6 of 34 (permalink) Old Jan 21st, 19, 09:40 PM
Tim
Pretty good price for those, was that a Craigslist find?
Just FYI, the 'high nickel' thing is just a myth, those numbers under the timing gear are foundry mold pattern references.
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is offline
post #7 of 34 (permalink) Old Jan 21st, 19, 10:10 PM Thread Starter
Tim
I'm not saying your wrong, but can you validate that with some objective evidence?
post #8 of 34 (permalink) Old Jan 21st, 19, 11:27 PM
Tim
Sure looks like it
Where is the 'objective evidence' that supports the high nickel story?
ZLP955 is offline
post #9 of 34 (permalink) Old Jan 22nd, 19, 04:27 AM
keith
X-77 keith's Avatar
I was always told that 010 means high Nicole too, but after a long thread on this site a year or two ago, I have my doubts. Wish the search feature here worked better. It was a long discussion. Regardless it is a good score.
X-77 keith
post #10 of 34 (permalink) Old Jan 22nd, 19, 04:46 AM Thread Starter
Tim
Sure looks like it
spend 30 seconds googling the subject and you get a bunch of "info" on the internet that talks about
the "high nickel content" in these early blocks, but your correct, I found nothing by general motors or the block manufacturers or any "authority" that support this.
just a bunch of guys talking about it on forums and what not.
Ok, so where do you get your information about the numbers just being a foundry mark?
anything by any "authority"? or just a bunch of guys talking about it on forums?
post #11 of 34 (permalink) Old Jan 22nd, 19, 06:31 AM
High nickle myth and foundry mark info at CRG.
engine block
1967 body tag vs vin tag
BLOCK CAST DATE VS PAD STAMP DATE
Niblet likes this.
Call for restoration and custom paint scheduling:
Sauron67MM is offline
post #12 of 34 (permalink) Old Jan 22nd, 19, 08:12 AM Thread Starter
Tim
I had no idea this was such a controversial subject, it appears there is no concrete proof either way
post #13 of 34 (permalink) Old Jan 22nd, 19, 09:18 AM
keith
X-77 keith's Avatar
There was a guy on this site that worked at a foundry he explained it. I wish I could find the thread. He explained that the 010 was just a foundry thing, and I have no reason to doubt him. I have never worked in a foundry. I wish Scott used my whole quote instead of just the short snip.
A side note... The block you have is still a great block .
Niblet likes this.
X-77 keith
post #14 of 34 (permalink) Old Jan 22nd, 19, 09:20 AM
Vega$69's Avatar
The preponderance of the evidence leans heavily towards it being a myth. Therefore I would assume myth unless additional conclusive facts are presented to the contrary.
Vega$69 is offline
post #15 of 34 (permalink) Old Jan 22nd, 19, 09:31 AM Thread Starter
Tim
I would say I have to agree with you on that
