what heads to use on my 385 stroker - Team Camaro Tech
 1Likes
post #1 of 18 (permalink) Old Jan 26th, 19, 03:41 PM Thread Starter
harvey
What heads would be good on my 385 stroker street & strip 10 / 5 /1 compression 3000 pds 373 gears automatic 4500 stall its an S10
pink panther is offline
post #2 of 18 (permalink) Old Jan 27th, 19, 08:42 AM
Simon
Re: what heads to use on my 385 stroker
With the information you provided.......I'm going to go out on a limb and suggest 200cc range aluminum heads as a possibly, if you can provide additional intake manifold, carb, camshaft product selections that you might want use or have then we could pinpoint a more accurate suggestion.
slazisme is offline
post #3 of 18 (permalink) Old Jan 27th, 19, 09:18 AM
Well you need to consider your torque converter stall speed with 3.73 rear gears because at 70 mph you will be turning 3,400 RPM. This means a lot of your engine's horsepower even with stock heads is being used to roast your transmission oil. You need a 4.88 rear gear to even lock up your converter at 72.2 mph at 4,500 RPM. I wouldn't consider this a street driven car.
It is all about the combination of parts.
Big Dave
Larger Dave is online now
post #4 of 18 (permalink) Old Jan 27th, 19, 05:11 PM
Need more info, like intended use, cam specs, ETC.
Torque monster, 185+cc heads and keep it under 6000
High winding street-strip machine 200+cc, 6800+ rpm.
Aluminum would be preferred
Whats your budget ?
https://www.profilerperformance.com/...ree-heads.html
or
Pro-Filer ECONO
68 Camaro~LSx ~all motor
post #5 of 18 (permalink) Old Jan 27th, 19, 05:53 PM Thread Starter
harvey
My heads are Liberty performances components Aluminum 200 cc are now getting ported along with 7530 team G intake iam getting a new cam roller I drive this on the street it's a street & strip
post #6 of 18 (permalink) Old Jan 27th, 19, 06:00 PM Thread Starter
harvey
What I really want to know will my heads work or do u think to small I run 11.53 1/4 mile now a solid flat tapped Lunati voodoo 1.6 553 lift with 373 gears
post #7 of 18 (permalink) Old Jan 27th, 19, 06:11 PM Thread Starter
harvey
O I have a 750 HP Holley double pumper
post #8 of 18 (permalink) Old Jan 27th, 19, 06:12 PM Thread Starter
harvey
4500 stall quick draw
post #9 of 18 (permalink) Old Jan 27th, 19, 06:26 PM
Steve69SS396's Avatar
Years ago I ran 11.20's at 120 in a 3,400 pound Camaro with a 355 running a set of AFR 210's that I purchased in 2000. My old AFR flow numbers were very close to the advertised flow of your heads. With more cubic inch and less weight it should run quicker than my car. And my car didn't 60 foot very well on the motor. The best it would do was 1.58. But on a 175 shot it was a different story. I was running a solid roller. You didn't give any details on your cam. It's flat tappet but you have more displacement than my car and less weight.
Steve69SS396 is offline
post #10 of 18 (permalink) Old Jan 27th, 19, 06:52 PM Thread Starter
harvey
My S10 is 3000 pds my cam. 276 _ 282 ave 520 _ 540 lift 241_ 249 fur 1.6 553 lift 110 lobe
post #11 of 18 (permalink) Old Jan 27th, 19, 07:48 PM
Run it. If it doesn't run quick enough put a solid roller in it.
post #12 of 18 (permalink) Old Jan 27th, 19, 08:36 PM Thread Starter
harvey
I was told I better not put a solid in but get a hyd Insted
post #13 of 18 (permalink) Old Jan 27th, 19, 08:38 PM Thread Starter
harvey
I drive it on the street about 1800 mile summer
post #14 of 18 (permalink) Old Jan 27th, 19, 08:43 PM
I've been running solid rollers on the street for 20 years. The 355 that I mentioned was 20 years ago when my car was a daily driver. Drove 3,000 to 5,000 miles a year. Cam was 264/274 @ 0.050" and 0.630" lift with 106lsa. Current cam in my 427 is 274/286 0.704" lift.
68rs406 likes this.
post #15 of 18 (permalink) Old Jan 29th, 19, 02:49 PM
Jack
Just for my info, what is your mph in the 1/4
67 Camaro Street car 3300 lbs
Flat Top 406 70cc Edelbrock RPM Heads
Q-jet comp xe268s 2500 stall converter
T-350 12 Bolt Posi 373's Cal-Tracs
60' 1.69
330' 4.950
660' [email protected]
1320' [email protected]
Fast Jack is offline
Scratching my bare head over heads for 68 R66 Engine 0 Aug 7th, 18 05:44 PM
BB heads SB heads Good Head options 71Vette77z28 Second Generation 9 Jul 25th, 18 09:01 PM
BBC 454 with 820 heads question socal_tom Engine 4 Mar 31st, 18 10:03 AM
Which Heads For My 396 Brettallen59 Engine 19 Mar 26th, 18 06:21 PM
421 and heads ? chadwick23 Engine 25 Dec 12th, 17 08:13 PM
