Edelbrok Head Really That Bad? - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 27th, 19, 09:17 AM Thread Starter
Are the Edelbrok RPM heads, 6089 (170) runners on a 388 really that bad? I have been talking with Chris Straub about running one of his cams with my Edel RPM heads on my 388. I know AFR's are better but how much better?
67 Camaro with 388 with Edleborck RPM heads, Air Gap, CC 282S, Tremec TKO
LukeSkywalker is offline
post #2 of 3 (permalink) Old Jan 27th, 19, 09:31 AM
Re: Edelbrok Head Really That Bad?
How much better? Just compare the flow bench numbers. Generally what ever the max air flow is in cfm you double to guestimate your gross horsepower. This assumes your cam and valve train can lift your valves that high. If not look to what your cam's valve lift actually is in your engine to get your actual flow potential. At which point the lower cost Edelbrock heads start to look much more attractive.
If you want to invest in HIGH RPM heads of any brand be prepared to run a solid roller, with matching springs, free flowing induction (I like a tunnel ram with two 660's) and an equally well flowing exhaust to move the quantity of air required to make the power you need to win a race. You will also need an ignition system to support that high RPM as even aftermarket HEI distributors can not fire the plugs reliably.
It is all about the combination of parts. It has taken me a half century to be able to put the right combo of parts together. Chris can tell you the same thing as he has been building engines as long as I have.
Big Dave
Larger Dave is online now
post #3 of 3 (permalink) Old Jan 27th, 19, 10:08 AM
Lonnie
Lonnie P's Avatar
In wouldn't say they are bad heads... but the 170cc runner is small for a 388 cu.in. engine. Unless you only want low end torque, such as in a towing application, you may be better suited to go with something in the 195cc range for an average street engine.
Lonnie P is offline
Small block chevy head gaskets X-77 keith Engine 5 Feb 13th, 19 05:09 PM
69 front tire leans in bad 69crush Brakes, Suspension & Steering 5 Sep 9th, 18 03:36 PM
Head Gasket Concern Deangelo66 Engine 4 Sep 5th, 18 12:53 PM
Scratching my bare head over heads for 68 R66 Engine 0 Aug 7th, 18 05:44 PM
head bolts flat tire Engine 2 Feb 2nd, 18 12:53 PM
