How fast??? - Team Camaro Tech
 4Likes
post #1 of 24 (permalink) Old Feb 4th, 19, 02:39 PM Thread Starter
DeAngelo
How fast???
I assume this is the right section for this. With an educated guess, how fast would a 67 be with a 735 hp/700 ft/lb big block, 4l80e, 3.73 gears, 275/40/17 MT ET Street SS radials? 0 to 60 and 1/4 mile. Thanks!
67 Camaro RS/SS
598 Crate Motor (original 350 on engine stand)
4L80e
Deangelo66 is offline
post #2 of 24 (permalink) Old Feb 4th, 19, 03:01 PM
kevin
Re: How fast???
1/4 Mile ET Calculator - RobRobinette.com
https://robrobinette.com/et.htm
This calculator estimates your 60 foot, eighth and quarter mile elapsed times and trap speed when given the weight of the car and flywheel or wheel horsepower.
‎Dyno Correction ‎Tire Diameter ‎Top Speed ‎Wheel Offset
flat tire is offline
post #3 of 24 (permalink) Old Feb 4th, 19, 03:15 PM
1Slow64
Re: How fast???
My S.W.A.G would be 9.90- 10.20 if car hooks. And that's assuming the numbers listed are at the wheel.
My 69 X66 project.
69X66 is offline
post #4 of 24 (permalink) Old Feb 4th, 19, 06:47 PM
Re: How fast???
Guesstimate.....
60 Foot E.T. : 1.37
1/8 Mile E.T. : 6.24 Speed : 108.90
1/4 Mile E.T. : 9.89 Speed : 135
68 Camaro~LSx ~all motor
post #5 of 24 (permalink) Old Feb 4th, 19, 08:26 PM
Vega$69's Avatar
Re: How fast???
All about getting it to the ground. If not then 13s if so low 10s high 9s
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #6 of 24 (permalink) Old Feb 4th, 19, 08:31 PM Thread Starter
DeAngelo
Re: How fast???
Thanks, Kevin!
Good point. I should have mentioned that was gross hp. I would guesstimate parasitic loss to the flywheel would be 40 or 50 hp. So, probably 690 at the flywheel. I asked because I wonder my car, when done, would compare to a Hellcat or new Z06. The Hellcat (non-widebody) is mid 11's and 0-60 around 3.7. The Z06 is about 11.0 and 3.0. That's fast!
Originally Posted by DOUG G View Post
Guesstimate.....
60 Foot E.T. : 1.37
My goal next year is to replace the 275's with 315's since it's been mini-tubbed. Thanks, Doug!
67 Camaro RS/SS
4L80e
post #7 of 24 (permalink) Old Feb 4th, 19, 08:33 PM Thread Starter
DeAngelo
Re: How fast???
Ha. So true. Hope I can with the Mickey Thompson's and 315's.
67 Camaro RS/SS
4L80e
post #8 of 24 (permalink) Old Feb 4th, 19, 08:37 PM
Vega$69's Avatar
Re: How fast???
And track location? Here in Vegas we have bad air. DA always over 3000
Vega$69 is offline
post #9 of 24 (permalink) Old Feb 4th, 19, 08:39 PM Thread Starter
DeAngelo
Re: How fast???
If I take it to the track, it would be in VA.
67 Camaro RS/SS
4L80e
post #10 of 24 (permalink) Old Feb 4th, 19, 08:45 PM
1Slow64
Re: How fast???
My 64 chevy II went 10.90's with a 611hp small block. That was through a powerglide and 4.88 gears though.
Deangelo66 likes this.
My 69 X66 project.
69X66 is offline
post #11 of 24 (permalink) Old Feb 5th, 19, 01:50 PM Thread Starter
DeAngelo
Re: How fast???
My other question is would I be able to keep up with or beat a Z06 or Hellcat on the highway or stoplight to stoplight?
67 Camaro RS/SS
4L80e
post #12 of 24 (permalink) Old Feb 5th, 19, 02:26 PM
Darin
ilikeike's Avatar
Re: How fast???
With traction control, be hard to beat those new cars on an oily street. I've ridden in both of those a few times, fast cars.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #13 of 24 (permalink) Old Feb 5th, 19, 04:20 PM
Re: How fast???
MIR
post #14 of 24 (permalink) Old Feb 5th, 19, 05:10 PM
Re: How fast???
The Z & Hellcat will have gearing to their advantage assuming yours/theirs HP/TQ are about the same. 4L80E is a 3 speed with OD and the others if stick are 6 and assume that or more if Auto's. Also their modern computer controlled traction control and suspension, unless you are also doing a 4 link or something, give them the edge.
Nothing wrong with bench racing....but the time slip is the bottom line. Get your combo dialed in and then go out and munch on some unsuspecting Hellcat or Z06 owned by , sadly, someone with enough $ to buy it but has no clue how to drive it and just let him go up in smoke as you pull away
SoCal805 is offline
post #15 of 24 (permalink) Old Feb 5th, 19, 05:56 PM Thread Starter
DeAngelo
Re: How fast???
Absolutely! My buddy has a Z06 and it is definitely fast!
Ha Excellent points. Thanks for responding.
67 Camaro RS/SS
4L80e
Car show experts X-77 keith Camaro Tech 95 Sep 23rd, 19 11:29 AM
The proper way to correct steering on 1st Gen w/o going overboard Nick_R_23 Brakes, Suspension & Steering 21 Nov 7th, 18 08:31 PM
anyone using a FAST 92mm intake Paul O LSx Swap 0 Jan 22nd, 18 06:13 PM
Cam and fast idle lever spring elan71 Engine 3 Dec 2nd, 17 08:10 AM
