Help ! High Idle after acceleration - Team Camaro Tech
 3Likes
post #1 of 18 (permalink) Old Feb 5th, 19, 05:15 PM Thread Starter
ME4NSTRK69's Avatar
Years ago my car was converted to power disc brakes. The brake booster was teed into the vacuum modulator. The car never stopped great. I have read this isn't a good thing to have it run this way. So I ran a new separate line from the booster to the manifold, a new line to the vacuum modulator line into the port on the front of the carb, and ran the pcv into the carbs large port in the back. Drove the car and the brakes definitely felt better. After getting on the car the idle went way up so I pulled over and shut the car off then restarted it and its fine. Ive been messing with it all day and drove it quite a bit. It hasn't done it since this morning. This happens sporadically.
The local parts stores here are out of the 11/32 brake booster line so I used a 3/8 pcv line for now for the brake booster vacuum line. Could the line be causing the issue ?
I used brake cleaner to test for vacuum leaks and I couldn't find anything, checked the manifold nipple baseplate spacers etc....
I Did just get the carb rebuilt ( pro form 650 double pumper ) also and it is running rich, I have to mess with it. I don't think the surge issue has anything to do with that though.
any ideas are appreciated thnx
69 camaro 350 pro form, double pumper 200r4
1969 Camaro 350 200r4 342 Posi
1987 WE4 Turbo Regal E85
2003 Sierra Stepside RCSB Belltech dropped
MY BUILD THREAD:
ME4NSTRK69 is offline
post #2 of 18 (permalink) Old Feb 6th, 19, 05:05 AM
Kevin
KevinW's Avatar
Re: Help ! High Idle after acceleration
Well, if it was running rich with no vacuum leaks, then you have a small vacuum leak. This would cause engine to no longer run rich, which may raise engine speed. It's a bit of a long shot.
My guess is your throttle plate/linkage got stuck, did you try pulling accel pedal up with your foot? (assuming you still have factory solid linkage)
Kevin
KevinW is online now
post #3 of 18 (permalink) Old Feb 6th, 19, 05:10 AM
Vega$69's Avatar
As you just re routed the booster hose maybe your throttle linkage is getting stuck by touching the hose?
ME4NSTRK69 likes this.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 18 (permalink) Old Feb 6th, 19, 05:30 AM
Make sure your choke isnt staying slightly closed
1969 Camaro LM1
chicoman is offline
post #5 of 18 (permalink) Old Feb 6th, 19, 07:19 AM Thread Starter
ME4NSTRK69's Avatar
Thnx for the replies I’ll try that with the pedal. Going to reroute the booster so it’s totally away from the linkage. Just have to find the right hose now.
MY BUILD THREAD:
post #6 of 18 (permalink) Old Feb 6th, 19, 08:19 AM
How is your return spring? When you manually turn the linkage under the hood, does it immediately come back and sit on the idle adjust screw?
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #7 of 18 (permalink) Old Feb 6th, 19, 01:36 PM Thread Starter
ME4NSTRK69's Avatar
yes it comes right back to the original position
MY BUILD THREAD:
post #8 of 18 (permalink) Old Feb 6th, 19, 02:13 PM Thread Starter
ME4NSTRK69's Avatar
I made sure it isn't touching and I also got the right power brake booster 11/32 hose still does it, its actually having the issue more often.
I tried to kick the pedal up did nothing.
Checked the booster check valve it is working as it should , so that's not it
I'm wondering if I have bad booster
I never had the issue when the brake vacuum line and the vacuum modulator were teed into each other but my brakes really didn't work well either. Since I ran the vacuum lines separate the brakes work better except when the car is having the issue and the idle is high then they feel like they used to.
MY BUILD THREAD:
post #9 of 18 (permalink) Old Feb 6th, 19, 05:29 PM
Power brakes work better because with the larger ID hose, more volume of vacuum.
I would disconnect and plug the booster vacuum line and test idle.
Yes brakes will require more pedal pressure, but you're looking for a lesser idle RPM.
If less, then leaky booster. Tried a hand vacuum pump on booster itself?
Doing a good job is like peeing in your dark pants Ö you get a warm feeling, but nobody notices
post #10 of 18 (permalink) Old Feb 6th, 19, 06:21 PM Thread Starter
ME4NSTRK69's Avatar
I haven't tried the hand pump yet but its a good idea, I did plug the booster vacuum line and drive it. The car barely stopped so I didn't go too nuts driving it. It was too busy a day by me too many people around.
I want to get the carb tuned also its pretty rich at idle then it surges after getting on it.
If it is the booster then I am just going to wait until I do the hydro boost and call it a day for now.
MY BUILD THREAD:
post #11 of 18 (permalink) Old Feb 9th, 19, 05:57 PM Thread Starter
ME4NSTRK69's Avatar
Put a spacer in between the linkage connection to the carb to eliminate some play in the original rod, haven't driven it yet. Not sure if it is catching the cable but It is very close so even if it doesn't fix the issue less play in the linkage is still good.
MY BUILD THREAD:
post #12 of 18 (permalink) Old Feb 10th, 19, 12:14 AM
David Pozzi
davidpozzi's Avatar
Check your distributor mechanical advance springs. Iíve seen that cause fast idle when weaker aftermarket springs are used.
davidpozzi is offline
post #13 of 18 (permalink) Old Feb 11th, 19, 04:16 AM
Kevin
Good point. I once forgot to remove the vacuum hose from the distributor when setting the advance, and could not figure out why I was not getting enough advance, or why the engine got to such a high idle when setting it to 8 degrees. I realized my mistake, unplugged the vacuum from the advance module, and it was much better when setting the initial timing!
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
post #14 of 18 (permalink) Old Feb 3rd, 20, 02:32 PM Thread Starter
ME4NSTRK69's Avatar
UPDATE :
Ending up that my power valve was bad and I had my carb rebuilt. Its been fine for a while then today after getting on it a bit the idle was stuck high again. Also when I shut the car off it stumbled and took a few seconds to turn off. Going to check the timing next and look at the distributor.
thnx for the replies
MY BUILD THREAD:
post #15 of 18 (permalink) Old Feb 3rd, 20, 02:44 PM
IDK about the Holly but my carb the front large vac port is for PCV and the rear feeds the brake booster/auto trans vac modulator
Make sure your carb linkage, and kick down cable if auto trans, are not preventing the carb to return to full close
SoCal805 is online now
High School SS Camaro was too "hot" jngillam New Member Introductions 8 Nov 26th, 19 12:26 PM
Supercharged '68 updates, upgrades, and tweaks SOAR B-1 Build Projects 77 Sep 21st, 19 11:58 AM
general idle setup question keithl1967 Engine 7 Jun 3rd, 18 10:48 PM
Are jets my next step? 4Speed67CamaroRS Engine 19 Apr 10th, 18 10:37 AM
