327 thrown rod - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 8th, 19, 08:15 PM Thread Starter
danny
327 thrown rod
400$ for a 327 with a thrown rod worth it or no?
camarolover#1 is offline
post #2 of 5 (permalink) Old Feb 8th, 19, 08:55 PM
keith
X-77 keith's Avatar
Any good parts on it? Like AFR heads, good carb and intake? If not, I would not give much at all for it. Thrown rod meaning the crank, rod, and the block are destroyed? Not much there to work with.
X-77 keith
X-77 keith is online now
post #3 of 5 (permalink) Old Feb 9th, 19, 06:54 AM
R66
Ron
Re: 327 thrown rod
Unless you disassemble it and look at the heads and crank and cylinder walls, it is a parts motor worth $50 to $100 or just junk. Depending on the year, casting number, application, etc. it could be worth more, and might be worth a bundle to the owner of a car that it came from.
I have a complete small journal 300 hp / 327 under the bench in excellent condition, that I feel is worth about $600, but will probably go to the junk as it seems everyone is going LS motors.
In central IL, old school 60s and 70s parts are still pretty cheap.
R66 is offline
post #4 of 5 (permalink) Old Feb 9th, 19, 10:59 PM
Joe
Re: 327 thrown rod
better open it up and make sure there is not a window in one of the cylinders!! I sure wouldn't pay any $400 for it. Maybe $50-150 if it was a buildable block and crank
The important thing here is that you ask me what kind of car I've got. "I've got a BITCHIN' CAMARO"
'68 350 4 speed
kookykrispy is offline
post #5 of 5 (permalink) Old Feb 11th, 19, 04:19 AM
Kevin
Re: 327 thrown rod
Will the seller allow it to be opened up and checked? As others have stated, a thrown rod can rip a hole in its cylinder wall, or chew up the journal on the crankshaft, or both.
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
Throttle rod to cable conversion Troutslayer Engine 14 Feb 21st, 19 04:57 AM
327 Ignition Condenser bsnowrider Engine 3 Oct 3rd, 18 06:32 AM
Door Latch Rod End Clip Andrew69 Interiors 3 Sep 7th, 18 11:30 AM
Tall ball joint and Tall tie rod question SC42 Brakes, Suspension & Steering 3 Mar 14th, 18 09:10 PM
Door lock Remote Control connecting rod - Orientation? 67moke Interiors 3 Jan 7th, 18 02:09 PM
