67 camaro ss 350 balancer info - Team Camaro Tech
post #1 of 8 (permalink) Old Feb 11th, 19, 09:22 PM Thread Starter
Apprentice
Rob
Hello i have a rusty 67 ss 350 car that had no engine. My son put a engine in and adding some correct parts along the way.. After looking for a correct balancer we are getting conflicting info.. the confusing part is the timing mark in relation to the keyway are they to be lined up or approx 8 Degrees off such as a 69 up..just dont want to buy the wrong one. Then onto the distributor and other pieces.
chevelle hunter 72 is offline
post #2 of 8 (permalink) Old Feb 11th, 19, 10:08 PM
Re: 67 camaro ss 350 balancer info
Pre '69, the timing mark will be inline with the keyway.
rodent4 is offline
post #3 of 8 (permalink) Old Feb 12th, 19, 08:04 PM Thread Starter
Apprentice
Rob
thanks, that's what I thought. now I need a 8 inch 67-68 balancer. I am summing they used the same part number for many yrs just the timing mark is what is what to watch for.
post #4 of 8 (permalink) Old Feb 12th, 19, 08:06 PM Thread Starter
Apprentice
Rob
anyone know if it's ok to use a 67 style 8 inch balancer once i find the correct one on a 69 and up 350 until i get the 67 engine rebuilt
post #5 of 8 (permalink) Old Feb 15th, 19, 07:47 PM
You should be OK. Just make sure that you use the correct timing chain cover or the correct timing tab.
TJS69 is offline
post #6 of 8 (permalink) Old Feb 15th, 19, 08:33 PM
For using a timing light the Stock balancer would have a etched mark.....I use Timing mark tape on the balancer. Cheap and available about any auto part store....even Autozone.
https://www.autozone.com/ignition/ti...cer/139829_0_0
SoCal805 is online now
post #7 of 8 (permalink) Old Feb 16th, 19, 08:02 AM
scblucam's Avatar
Yeah I did that, Clean balancer apply tape set timing. First I blipped the throttle never saw it again.
68 302 M20 - 85 IROC Z
scblucam is offline
post #8 of 8 (permalink) Old Feb 16th, 19, 08:39 AM
Bobby
Same here. Put new tape on and then clear-coated it, holding out pretty good now.
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180° Headers
black/black
no radio
Luwi67 is offline
Is a 67 Firebird rear seat the same as 67 Camaro deluxe 68resto Interiors 2 Nov 14th, 18 08:32 PM
67 camaro ss 350 air cleaner base 69 JL-8 Camaro Tech 3 Sep 27th, 18 10:19 PM
67 396 harmonic balancer Mperk755 Camaro Tech 2 May 8th, 18 10:18 AM
67 Camaro 350 with 3892657 casting wanted Mkov.1969 Engine 2 Apr 3rd, 18 08:48 PM
