Here's one for you, 8" balancer - Team Camaro Tech
 3Likes
  • 2 Post By Vega
  • 1 Post By stevo camaro
post #1 of 8 (permalink) Old Feb 21st, 19, 09:10 PM Thread Starter
stevo camaro's Avatar
So, have the 454 in the car right now with an 8" balancer, problem is, I also have a 1 1/8" sway bar in the car. Never heard anything, never felt anything, but today I see that they are making contact. Wow! Good thing I haven't put alot of miles on this car yet. The 427 will be ready for the car in a couple of weeks and I'm gearing up for that switch. I DID have a 8" balancer for that motor as well. Until today. Looks like I'll be getting the smaller balancer. They're what? 7 1/4"? And I doubt this would've been an issue with the stock sway bar. I'm still in shock that got by me somehow. Did I mention I'm getting old? LOL I'll take a pic tomorrow and show you. Unbelievable.
67 RS 327, 4-speed, posi, done.
67 Modified, 454, TH-400, posi, under construction.
67 SS 396, 4-speed, basket case.
72 RS, sitting, partially done.
55 210 post, 2 door, 327 4-speed runs good.
55 2 door post, gasser project
69 Cadillac ElDorado
69 4x4 suburban
59 ElCamino
Some mornings, it's just not worth chewing thru the leather straps"
stevo camaro is offline
post #2 of 8 (permalink) Old Feb 22nd, 19, 03:39 AM
Vega$69's Avatar
Re: Here's one for you, 8" balancer
Why not just add a spacer to lower the sway bar 1/4 to clear the balancer?
DOUG G and Just 1 More like this.
Vega$69 is offline
post #3 of 8 (permalink) Old Feb 22nd, 19, 05:22 AM
Ben
Had same problem with small block 400 & 8" balancer barely clearing 1.25" sway bar. Add 1/8" spacers between sway bar mounts and subframe. it will bring the bar down enough to clear without sacrifice in performance
bhodgdon400 is offline
post #4 of 8 (permalink) Old Feb 22nd, 19, 08:08 AM
Rick
I had that problem and found out I had the wrong end links.
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is online now
post #5 of 8 (permalink) Old Feb 22nd, 19, 09:02 AM Thread Starter
Spacers, good idea. I'll look at that today.
bhodgdon400 likes this.
69 4x4 suburban
59 ElCamino
post #6 of 8 (permalink) Old Feb 22nd, 19, 03:07 PM
Rick
With the correct links, there are short and long, the sway bar should be parallel to the ground give or take.
rp930 is online now
post #7 of 8 (permalink) Old Feb 22nd, 19, 03:26 PM
Spacer worked for me also
68 Camaro~LSx ~all motor
post #8 of 8 (permalink) Old Feb 24th, 19, 06:07 PM Thread Starter
Not touching sitting on the ground, got a half inch clearance. But I think it made contact driving at some point. When you lift the car and everything drops, it makes contact. I will be shimming it, looks to be an easy fix. The links are correct, it sits flat at ride height.
69 4x4 suburban
59 ElCamino
67 camaro ss 350 balancer info chevelle hunter 72 Engine 7 Feb 16th, 19 08:39 AM
DZ 302 Harmonic Balancer hunt...Which one??? Yellow69RSZ Engine 12 Jan 25th, 19 08:43 PM
8" vs 6" Harmonic Balancet Craig1969 Engine 9 May 28th, 18 05:49 PM
Harmonic Balancer Came Off mfeets Engine 4 May 9th, 18 04:35 PM
67 396 harmonic balancer Mperk755 Camaro Tech 2 May 8th, 18 10:18 AM
