Dart 406 small block build - Team Camaro Tech
 2Likes
  • 2 Post By travisch
post #1 of 10 (permalink) Old Feb 25th, 19, 09:05 AM Thread Starter
RJ
Hello,
I have a Dart 406 small block with 11:1 pistons, stainless bottom end, Dart aluminum heads, Dart intake, and a load of other stuff. It runs great, reasonably steerable. It's a 4-speed car, 4.11 gears.
I love the motor, but it's not the ideal vehicle for a road trip. Considering toning it down a tad, but only to include a cam change, maybe different intake, but not sure how to proceed. Interested in opinions and options. I had the cash back then, and went a bit overboard on everything, against all of your opinions, haha. Would appreciate maybe getting some opinions on max size hydraulic roller, should i go to dual plane intake, heads are 215cc darts.
Richard
69 Camaro RS, Dart 406" small block, 11:1 CR, Muncie 4-Comp Cams XR300HR, Dart 215cc aluminum heads, Dart single plane, Hooker 2" ceramic headers Richmond 4:11 rears.
aircavalryveteran is offline
post #2 of 10 (permalink) Old Feb 25th, 19, 09:28 AM
Re: Dart 406 small block build
What specific issues are you having with the motor while attempting to cruise?
Big Dave
Larger Dave is offline
post #3 of 10 (permalink) Old Feb 25th, 19, 11:48 AM
Travis
Curious what the issues are as well.
My guess is you are wound up alittle tight on RPMs running down the highway. If this is the case then I'd look at a 5 speed swap or a re-gear before I changed anything with the engine. Sure, its going to cost more that swapping the cam but the results are much better/larger - money better spent IMO.
jimnecci and 69X66 like this.
travisch is offline
post #4 of 10 (permalink) Old Feb 25th, 19, 02:42 PM
regardless of what you do to the engine...any tranny that has a final gear of 1:1 with 4:11's is not good for a Hwy "road trip" cruiser.
Go to a higher (3.08) gear...or get some big a** tires
Gears are about $200 so if you install yourself that is likely the cheapest path.
I just switched from 3:73 to 3.08 for the same reason. Some day when I do a new motor I will go TKO or 700R4 and put the 3.73's back in
SoCal805 is offline
post #5 of 10 (permalink) Old Feb 25th, 19, 03:21 PM
One issue I see with the OD trans is 1st gear will be about useless.
What cam in it now ?
3.08's would be nice for cruising, but that motor won't like it much.
3.73's is only about a 300 rpm drop.
3.5X wouldn't be too terrible.
I feel your pain though, 4.10's and a th350 is 3500rpm at 60-65 MPH here. Fun for the first 10 minutes
68 Camaro~LSx ~all motor
post #6 of 10 (permalink) Old Feb 25th, 19, 04:32 PM
FWIW dropping from 3.73 to 3.08, for me, was a 600 RPM drop at 65 mph.....YMMV
OP, you can use this RPM calculator with your 411 to see what RPM a particular rear gear will get you
https://spicerparts.com/calculators/...rpm-calculator
SoCal805 is offline
post #7 of 10 (permalink) Old Feb 25th, 19, 06:10 PM
Showed 800ish 4.10 to 3.08 on mine.... not accounting slip. (automatic)
Would still like cam specs
post #8 of 10 (permalink) Old Feb 27th, 19, 10:11 AM
1Slow64
5 speed
My 69 X66 project.
69X66 is offline
post #9 of 10 (permalink) Old Feb 27th, 19, 02:24 PM
the BOSS&Ralph
Something to keep in mind when trying to make a high compression engine more street friendly is that a smaller cam may push it into detonation. The same issue can occur as you lower cruise rpm.
friendlyviper is offline
post #10 of 10 (permalink) Old Feb 27th, 19, 04:44 PM
Sean
Thatís an excellent point.
Does it run on pump gas without issues?
Is it the motor or would an over drive help with your main concerns of being able to cruise it?
Sean
Franklin D. Roosevelt
68rs406 is offline
Heat riser -fitment big block vs small block xxxg00w0pilot Engine 4 Aug 26th, 18 02:48 AM
Need expert opinions 1967 RS SS 4 speed small block ?? 69crush What's it worth? 3 May 24th, 18 10:31 AM
Correct starter brace for '68 small block ??? daven1256 Restoration Corner 9 May 19th, 18 07:27 PM
calling all small block chevy builders travisch Engine 20 Mar 6th, 18 05:14 AM
