69 BB 396 motor mounts - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 8th, 19, 09:39 PM Thread Starter
Michael
Doing a complete resto on a 69 camaro x22 396.Bought performance motor mounts and the engine is to tight and will not set into the frame mounts.Has anyone had this problem with after market motor mounts?I pulled a 396 out of the car so waiting for stock mounts.
1969
mpeters is offline
post #2 of 4 (permalink) Old Mar 9th, 19, 10:49 AM
Re: 69 BB 396 motor mounts
There are two different motor mounts: the early tall and narrow style (1958-'68), and the later wide and short style used from 1969'-'72.
Here is a note from Energy Suspension reference their part number 3-1117G
This is the early style "tall and narrow" motor mount that measures 2 3/8 in. between the ears and 2 3/16 in. tall to the center of the through bolt hole. Must have narrow type frame brackets to use these mounts.
You should have a short and wide engine mount to fit your '69 frame stands.
Big Dave
Larger Dave is offline
post #3 of 4 (permalink) Old Mar 14th, 19, 09:02 PM
Red face Re: 69 BB 396 motor mounts
It sounds to me like you have the short and wide engine mounts. These are for the 67-68 Camaro's. The 1969 uses the tall and narrow engine mounts. If your frame stands are the original stands for a 1969 you want the tall and narrow mounts.
URL=https://s263.photobucket.com/user/tjs69_photos/media/engine%20and%20frame%20mounts/2267Anchor67-69307-327-tile_zps1e1b9ef3.jpg.html][/URL
Many parts houses and parts books are wrong on this. The above chart should help.
TJS69 is offline
post #4 of 4 (permalink) Old Mar 14th, 19, 09:24 PM
Jon
I'd bet all you need is a little help from a Ford adjusting tool, AKA a big hammer. Fit the mounts to the stands before bolting them to the block. It works wonders knowing they fit the stands before dropping the complete engine in all at once.
Jon N
dyno jonn is online now
69 Camaro, straight 6 to 396 Heftyspencer88 Restoration Corner 5 Sep 28th, 18 06:41 AM
New here - 69 SS 396 surgeon michael New Member Introductions 13 Jul 3rd, 18 06:00 AM
69 396 L89 Block? dt69usa What's it worth? 4 Jan 6th, 18 08:28 AM
69 396 temp sensor part number scottcleaver Camaro Tech 5 Dec 29th, 17 06:15 AM
