67 L30 327 head? - Team Camaro Tech
post #1 of 12 (permalink) Old Mar 11th, 19, 09:59 AM Thread Starter
67 L30 327 head?
What cast markings did the heads have on the fronts?
double hump or?
SoCal805 is online now
post #2 of 12 (permalink) Old Mar 11th, 19, 10:34 AM
Ed
bertfam's Avatar
Re: 67 L30 327 head?
The 1967 L30 (327/275) head used either the 3890462 (early) or the 3917291 (late) with 1.94" intake and 1.50" exhaust valves. Both heads used the double hump symbol.
Ed
Ed B. (but you can call me Bert!)
CRG -
bertfam is online now
post #3 of 12 (permalink) Old Mar 11th, 19, 11:09 AM Thread Starter
Did the 462's also have 1.94/1.50 valves?
post #4 of 12 (permalink) Old Mar 11th, 19, 11:44 AM
There were 3 different xxxx462 heads manufactured from 62-67. You need to know
what full casting number you have. See the chart about 1/3 of the way down this page.
https://www.enginelabs.com/engine-te...ads-to-gen-iv/
my 67' build thread:
allanjs is offline
post #5 of 12 (permalink) Old Mar 11th, 19, 12:00 PM
Ed
bertfam's Avatar
I'm assuming you mean the 3890462 heads, and yes, they came with either 2.02 or 1.94 intakes depending on what engine they were being installed on.
Ed
CRG -
post #6 of 12 (permalink) Old Mar 14th, 19, 09:38 AM Thread Starter
Was there a cam spec difference between the 210 hp 327 and the L30 327 that had 275?
post #7 of 12 (permalink) Old Mar 14th, 19, 09:43 AM
Ed
bertfam's Avatar
Nope. The same cam (P/N 3896929, casting number 3896930) was used on the 1967 283/195, 327/210, 327/275, 327/300 and 350/295).
Ed
CRG -
post #8 of 12 (permalink) Old Mar 14th, 19, 09:43 AM
Jon
3896929 camshaft was used for both of them. (Edged out by a nose..... )
Jon N
dyno jonn is offline
post #9 of 12 (permalink) Old Mar 14th, 19, 10:06 AM Thread Starter
So the 65 hp increase was all in the heads. The 1.94/1.5 double humps vs the 2.02/1.6?
I would have thought a different cam that made more power in higher RPM
Interesting it was the same cam in 283-350 motors
post #10 of 12 (permalink) Old Mar 14th, 19, 10:30 AM
Jon
No 202's on L30's, just more compression and a bigger carb.
Jon N
post #11 of 12 (permalink) Old Mar 14th, 19, 10:34 AM
Ed
bertfam's Avatar
Heads, yes, but not what you stated.
The heads on the LF7 (327/210) used 1.72"/1.50" valves and a Combustion Chamber volume of 75.340cc.
The heads on the L30 (327/275) used 1.94"/1.50" valves and a combustion chamber of 63.305cc.
The larger valves on the L30 increased breathing, but more importantly, the smaller cc size raised the compression ratio from 8.75:1 (327/210), to 10.00:1 (327/275).
Same block, same pistons, same cam, but the increased compression ratio of the L30 heads made the difference.
Ed
CRG -
post #12 of 12 (permalink) Old Mar 14th, 19, 10:45 AM Thread Starter
So the 65 hp increase was all in heads (valve size and tighter chamber for more compression)
I have a Gen 2 LT1 in a 96 Impala (it's a 383 AL head/T56 car now). Everything Chevy made 94-96 came with a LT1 but the cam & heads were different between models. B body's got the iron heads with a cam designed to make more low end TQ 260 hp. F body got the aluminum heads and a cam that made a little more power in the upper RPM's and also "slightly" higher compression 270 hp. The Y body also got aluminum heads and a slightly more aggressive cam, 4 bolt mains and made 300 hp (of course GM needed to keep the Vette at the top of the pack)
Interesting GM did it all with heads and carburation on otherwise identical short blocks/cams for the Gen 1 motors
Mid Length Headers 67 327 SoCal805 Exhaust and Headers 2 Jan 28th, 19 09:49 AM
1967 Camaro 327 L30 4 Speed Adding Headers 351just Exhaust and Headers 6 Nov 24th, 18 10:37 AM
Engine Pics - 1968 RS L30 327 ghamnik Engine 2 Jul 24th, 18 12:44 PM
Just bought a 67 L30 / M20. Here's the numbers: LS 1st Gen Tag Team 19 May 22nd, 18 10:28 PM
head bolts flat tire Engine 2 Feb 2nd, 18 12:53 PM
