Drivers side motor mount - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 12th, 19, 06:33 AM Thread Starter
Kevin
In a thread last week, I mentioned installing power steering for my 67. The first step that I want to do is install the power steering pump adjusting bracket that goes over the drivers side motor mount. In order to do this, I have to remove the upper left and lower center bolt of the solid rubber engine mount. Can I remove the long vertical bolt and nut, then jack the engine up enough to access these two bolts? The engine I think would pivit on the passenger side motor mounts long bolt. I might have to remove the fan in order to keep the blades from hitting the shroud, but that's not hard.
In that other thread it was stated I could use the Z28 type bracket, but I don't want to change to an 8 inch harmonic balancer to use the Z28 bracket since I already have everything needed for this conversion to power steering using the 327/L48 brackets.
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
post #2 of 3 (permalink) Old Mar 12th, 19, 09:57 AM
Re: Drivers side motor mount
I kind of doubt you can rotate the engine enough to gain access to the lower center bolt.
The trans mount might bind also. I think you'd be better off to raise the front of the engine.
Watch the distributor. Might have to pull it for clearance. You DO NOT have to run an 8"
balancer with the Z28 style brackets. They work fine with the smaller balancer.
my 67' build thread:
allanjs is offline
post #3 of 3 (permalink) Old Mar 12th, 19, 07:25 PM
Nick
I've done it many times just use flex sockets and make sure you have a 2x4 under the oil pan just in case it drops on you.. undo the shroud instead of the fan much easier :P
67 rs/ss 350 original eng,700r4, a/c, tilt, deluxe int,strato bench,Ca.emission,front disk,am/fm,floor clock,17" W/V Ralleys,Toyo T1S 255/40/17, 245/40/17
MRCOOL_RSSS350 is offline
Rear wheels shifted towards the driver's side Mike L Brakes, Suspension & Steering 3 Aug 22nd, 18 10:19 AM
1968 RS drivers side headlamp assembly installation help j79l82 Body Shop 0 May 23rd, 18 03:48 PM
Are jets my next step? 4Speed67CamaroRS Engine 19 Apr 10th, 18 10:37 AM
