Solid motor Mount Question - Page 2 - Team Camaro Tech
 1Likes
post #16 of 20 (permalink) Old Mar 22nd, 19, 04:28 AM Thread Starter
Ben
Re: Solid motor Mount Question
Originally Posted by Vega$69 View Post
Maybe just NEW rubber or poly mounts instead of some old ones that were just laying around for who knows how long or condition?
LOL, yea, probably would've been a better idea but you know how it is....why buy it when you've got it?.....lesson learned.
are the poly mounts less prone to splitting and separation? seems like it hasn't taken much to rip the rubber ones. i've never even put slicks or drag radials on the car and tried to get it it to hook. still ripping rubber mounts with just some street driving and possibly the occasional full throttle 3 gear slide away from a light...
bhodgdon400 is offline
post #17 of 20 (permalink) Old Mar 22nd, 19, 05:18 AM
Rick
I use a solid left and rubber right.
dyno jonn likes this.
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #18 of 20 (permalink) Old Mar 22nd, 19, 08:37 AM
Yes all polyurethane mounts are interlocking so they can not separate. Factory had interlocking motor mounts as well but they were only factory installed on engines rated above 300 horsepower. Everything else still got the glued together (Vulcanized) motor mounts that prompted the very first ever factory safety recall in 1970.
Big Dave
Larger Dave is online now
post #19 of 20 (permalink) Old Mar 22nd, 19, 11:23 AM
kevin
back in the day they used a chain or turn buckle
I still use the turn buckle today as a safety devise
flat tire is offline
post #20 of 20 (permalink) Old Mar 22nd, 19, 03:36 PM
Sean
Solid mounts for the right engine size are a direct replacement for rubber/poly, so you’ll be fine.
Solid are not as harsh as people think, but you will notice it.
That said, unless you are making crazy power and hooking hard or just generally beating the hell out of the car a good poly or even rubber replacement should not break.
I have poly engine mounts and a rubber trans mount, mines an automatic so not quite as violent as a gear car, but they have lived for years behind a 500 horse 406 with a lot of 1/4 mile passes, and now a 600+ ish motor (but no passes yet). You don’t need solids unless racing or lots of power and hook.
The old cable or chain or whatever was a bandaid for the non captive type motor mount, so there is no reason for that mess (in my opinion) to be hanging off the side of your motor. I don’t think you can buy a non captive mount anymore.
But hey, if you want them solids will be fine, just not necessary in my opinion.
Sean
Franklin D. Roosevelt
68rs406 is offline
70 Restomod Coil Over Question Craig1969 Pro Touring 12 Feb 5th, 19 11:23 AM
Starter Wiring Question - Bracket ID OUTarHeel Engine 3 Dec 19th, 18 03:22 AM
Brake line question Cunning69 Brakes, Suspension & Steering 8 Aug 3rd, 18 05:53 AM
Question about 12 Bolt Axle Tube Repair Brettallen59 Restoration Corner 4 Feb 14th, 18 03:05 AM
Dumb M20 Question. timntexas Transmission & Driveline 14 Dec 10th, 17 08:08 AM
