Mechanical fuel pump diaphragm - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 21st, 19, 05:11 AM Thread Starter
Kevin
In another thread about ethanol fuel additives being used and its effect on a Holley excelerator pump diaphragm, it made me wonder if ethanol had any effect on the mechanical fuel pump diaphragm.
Does it?
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
post #2 of 5 (permalink) Old Mar 21st, 19, 07:40 AM
Rick
Re: Mechanical fuel pump diaphragm
Here's a small/quick read on the subject.
https://carterfuelsystems.com/resour...ect-of-ethanol
Rick
Sam 15 is offline
post #3 of 5 (permalink) Old Mar 22nd, 19, 03:19 AM Thread Starter
Kevin
Good info if your using a Carter brand electric fuel pump...how about a mechanical fuel pump?
bucko is offline
post #4 of 5 (permalink) Old Mar 22nd, 19, 08:26 AM
Rick
Hagarty article
https://www.hagerty.com/articles-vid...ethanol-in-gas
Rick
Sam 15 is offline
post #5 of 5 (permalink) Old Mar 22nd, 19, 08:46 AM Thread Starter
Kevin
That helped. Thanks. I can say though that my lawn mowers get a goo buildup in the bowl when they sit for a month without use.
bucko is offline
Mechanical Fuel Pump Failure? ctcz28 Engine 11 Aug 12th, 18 07:34 PM
Electric fuel pump questions bucko Electrical & Wiring 17 Jul 20th, 18 04:37 PM
Fuel Pump Diaphram failed (twice)? fredd7924 Engine 3 Jul 10th, 18 05:50 AM
fuel containing ethanol may go away flat tire Bench Racing 8 Jun 8th, 18 09:40 PM
Are jets my next step? 4Speed67CamaroRS Engine 19 Apr 10th, 18 10:37 AM
