Efi sos! - Page 13 - Team Camaro Tech
 38Likes
post #181 of 209 (permalink) Old Jun 16th, 19, 09:22 PM
Bryan
Re: Efi sos!
Originally Posted by Milt's 68 SS/RS 396 View Post
I am doing all tuning through the handheld device. I'll post the last data log I recorded tomorrow and see if I can find the configuration file (need to watch the complete video posted above). I have also bought a relay and will rewire the Sniper and the Hyperspark distributor off of the relay instead of the ignition connection on the fuse panel.
Here is a quick description on how to do it. Basically you need to save the GCF to the SD card, take the card to your PC, save it, and then you can either open it and edit it with the Sniper software, or email it, upload it, etc.
https://forums.holley.com/showthread...8883#post98883
1968 Camaro, 383 with Dart Pro 1 aluminum heads and roller cam, Holley Sniper EFI with Dual Sync distributor, Muncie M21 4-speed transmission, 3.73 12-bolt Eaton posi differential.
Bry68 is offline
post #182 of 209 (permalink) Old Jun 17th, 19, 10:43 AM Thread Starter
Milt
Milt's 68 SS/RS 396's Avatar
Re: Efi sos!
Bryan thanks for this information. I'll record the config file this evening. I'm having trouble attaching the data log to this post. Message is telling me dlz format is not allowed.
Go big, or stay Home!
Milt's 68 SS/RS 396 is offline
post #183 of 209 (permalink) Old Jun 17th, 19, 06:50 PM
Greg
Re: Efi sos!
Not sure if the rules are the same on this forum but on the Holley site you have to zip the file before you can post it on the forum. Saving it to Dropbox is another option.
69 Camaro, 3650lbs., 400ci, TH400, Coan 10" converter, 3.50 gear
D1SC, pump gas, 9:1, 10 PSI, Water/Meth injection
1.325 60', 5.988 @ 115.4 (carb)
Switched to Super Sniper EFI 2019
Greg O is offline
post #184 of 209 (permalink) Old Jun 20th, 19, 01:48 PM Thread Starter
Milt
Re: Efi sos!
Latest update. I rewired the power to the Sniper, Distributor & Coil Driver module. They are all coming off o a relay now. Next step is to set-up the idle per the EFI System pro instructions found here:
https://www.efisystempro.com/efi-pro...roubleshooting
Still have not heard back from Holley about the data log I sent them.
Probably will be a couple weeks before I can get back into this anyways.
post #185 of 209 (permalink) Old Jul 4th, 19, 10:10 AM Thread Starter
Milt
Re: Efi sos!
Got up this morning and disabled the closed loop as John suggested. Brought the car up to temperature and It still died. If anyone knows of a shop in Las Vegas that has knowledge of these systems I'm ready to let someone else fix this.
post #186 of 209 (permalink) Old Jul 4th, 19, 12:39 PM
Re: Efi sos!
Do you have electric fans? Is it when the fans turn on that it dies?
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #187 of 209 (permalink) Old Jul 4th, 19, 04:12 PM
Vega$69's Avatar
Re: Efi sos!
Pm sent
dhutton and Brettallen59 like this.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #188 of 209 (permalink) Old Jul 4th, 19, 05:29 PM Thread Starter
Milt
Re: Efi sos!
Originally Posted by Vega$69 View Post
Pm sent
PM received and thank you.
post #189 of 209 (permalink) Old Jul 4th, 19, 05:31 PM Thread Starter
Milt
Re: Efi sos!
No electric fans. 7 blade clutch fan with big block shroud.
post #190 of 209 (permalink) Old Jul 4th, 19, 05:39 PM
Rufas
Re: Efi sos!
I have responded to over 20 emails of late about electronic ignition for the Sniper, and I have said that the Sniper isn't the friendly system it claims to be, far too intensive to work with, and as far as ignition goes, there is not a viable solution. their dual synch is way, way too expensive, and the trigger only with adjustable rotor is down right primitive. I am also hearing the same for one of the FiTech EFI's, same situation, ignition input does not use a module, only a locked out pickup trigger only.
A couple of people have swapped to th Holley Terminator, and old small diameter stock GM EFI HEI distributor with feed back module, and are seriously happier, their opinions, not mine.
Don't flame me, this is what I put up with every day. I am now doing two International Harvester Sniper setups, and they do not have adjustable rotors, but, I am factoring the rotor phase into the timing as I phase them on the machine. So far, I understand from the callers and emails, that I am the only one that will even consider doing an ignition for a Sniper that ISN'T an MSD trigger for Chevrolet/GM units with adjustable rotor.
Terminator is far better from what I see. I used to work at Holley, Pro-Stock carbs.
dave ray is offline
post #191 of 209 (permalink) Old Jul 4th, 19, 05:59 PM
Brett
Re: Efi sos!
Dave (Rufas), I applaud you for making the effort to improve upon a very popular concept to make it even more popular...
Kudos
Brett.....
1969 SS 396 X66 - RS Conversion - TKO600 - 3.73 Posi - Paint Code 71-LeMans Blue
Brettallen59 is offline
post #192 of 209 (permalink) Old Jul 11th, 19, 05:01 PM
Re: Efi sos!
Is John going to take a look at this for you?
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is online now
post #193 of 209 (permalink) Old Jul 11th, 19, 09:00 PM
Apprentice
david
Glad I bought the edlebrock efi pro flo 4th gen. Bolted it on and never a problem. See YouTube search dlk014
1967 base hugger orange 383 stroker
davidinphx is offline
post #194 of 209 (permalink) Old Jul 11th, 19, 09:02 PM
Apprentice
david
Not 3rd gen I got 4th gen
post #195 of 209 (permalink) Old Jul 12th, 19, 01:16 PM Thread Starter
Milt
Re: Efi sos!
At some point, we need to coordinate our schedules. I'm out of town for the next week, so it will have to wait a bit longer. In the meantime I have sent the config file & saved data log to Chris with EFi sytem pro. He thought as others have that it was an electric fan causing interference, but since I don't have that on my car it must be something else. I'm curious to see what he thinks once he views the data log.
FiTech EFI Throttle Bodies and LS Swap Harness/Computers! MCB Sponsors 1 Jan 10th, 19 01:18 PM
EFI Fuel Pump Wiring? OUTarHeel Electrical & Wiring 2 Nov 27th, 18 05:49 AM
Help with Carb problem or go EFI? ctcz28 Engine 47 Nov 16th, 18 08:40 AM
BLACK FRIDAY NOW! FiTech EFI Systems and LS Kits MCB Sponsors 0 Nov 12th, 18 12:16 PM
Converting to EFI and need some fuel line/ fittings help wonder squirrel Engine 1 Apr 28th, 18 03:57 PM
