327 Small Block Starter Options - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 8th, 19, 09:42 AM Thread Starter
Apprentice
Kurt
Hey all, running a TSP 376 small block (12621766) and I bought a Quicktime bell housing RM-6036 (6036G18S) to fit a tremec 5 speed but the starter won’t fit.
Was thinking of grinding down the oem part sent but even with the fit, it will leave a gap with the bell housing starter gear area.
Hopefully I explained this is a somewhat logical way. Any help would be greatly appreciated. Will try and get some pictures to explain.
Kcarn is offline
post #2 of 5 (permalink) Old Apr 10th, 19, 03:45 AM
Kevin
Re: 327 Small Block Starter Options
I would not modify/grind any part to make it fit, as it becomes non returnable if its modified. Hopefully some one here with that experience will chime in. If not, I'd call the manufacturer of the transmission to see if they can shed any help on what starter works with your engine/trans combination.
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
post #3 of 5 (permalink) Old Apr 10th, 19, 07:11 AM
Darin
ilikeike's Avatar
I run the Quicktime bell and a Powermaster 9612 starter, I didn't need to grind anything.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #4 of 5 (permalink) Old Apr 12th, 19, 05:06 AM Thread Starter
Apprentice
Kurt
Do you know what size bolts go in for the bellhousing? I’ve ordered the ones from QuickTime and have tried several others from an auto part store but the closest one we got thread in about a quarter of the way and bottom out/get stuck.
Kcarn is offline
post #5 of 5 (permalink) Old Apr 12th, 19, 01:32 PM Thread Starter
Apprentice
Kurt
Specifically the transmission bolts
Kcarn is offline
Dart 406 small block build aircavalryveteran Engine 9 Feb 27th, 19 04:44 PM
Incorrect starter brace ??? daven1256 Camaro Tech 17 Feb 21st, 19 07:10 AM
Heat riser -fitment big block vs small block xxxg00w0pilot Engine 4 Aug 26th, 18 02:48 AM
Correct starter brace for '68 small block ??? daven1256 Restoration Corner 9 May 19th, 18 07:27 PM
