302 DZ help - exhaust blocked or restricted? - Team Camaro Tech
 1Likes
post #1 of 22 (permalink) Old Apr 11th, 19, 09:03 AM Thread Starter
Chuck
Send a message via AIM to ChuckD Send a message via MSN to ChuckD
Hey Gang, I have been wrestling for several years to get this DZ motor to run right. I have been through the carb, curved the distributor, set valves, re-located vacuum advance, and followed most everybody's suggestions. However, I can't understand why I have such a fat-rich idle, and a dying car at hot idle. Above 2500 RPM, it runs just fine, but burns gas like crazy. Oil does not seem to be contaminated.
FYI...the exhaust sat on the garage floor for 3-4 years during a re-do, and when I initially started the car after the engine was done and the exhaust put back on, mouse blew out the tail pipes. This car has great and even compression, clean carb with proper jets and PV, solid ignition, and runs to 6500 RPM without a miss. Idle is set at 950, 14-16 degrees advance initial, and I get 10.5 inches of vacuum. Drive it for 15-20 minutes, and it won't idle, temp is 180-190. Could it be that the mufflers are just internally rusted as the car sits for many weeks/months between drive intervals? Mufflers are 20 years old at least. Help me Obe-Wans!
69 Z-28-Glacier Blue, X-77
ChuckD is offline
post #2 of 22 (permalink) Old Apr 11th, 19, 03:05 PM
Re: 302 DZ help - exhaust blocked or restricted?
Do you have the correct PCV valve. Are the floats set correctly. You’re sure the balancer is correct with the timing mark in the right place. The coil and the condenser in the distributor if bad will fail when the engine gets up to temperature. Just giving you my experiences over the years.
1969 Z28
1969 Firebird 400
My new project for 2010 DONE/ Sold.
2002 Camaro SS LE/SLP
67 Nova SS 327, M20, 3.73
nashcar is offline
post #3 of 22 (permalink) Old Apr 11th, 19, 03:21 PM
True dual exhaust ? Does the pressure feel the same on each tailpipe ?
Have you tried open headers ?
68 Camaro~LSx ~all motor
post #4 of 22 (permalink) Old Apr 11th, 19, 05:23 PM
I have to agree in the lines of possibly the coil as I had a coil go bad on a 69 BB and it ran fine when cool and terrible when fully warm. At least its an inexpensive thing to try and rule out, good luck!
Mostly Camaros and FINALLY a Double Nickel
Yellow69RSZ is offline
post #5 of 22 (permalink) Old Apr 11th, 19, 06:39 PM
Morgan
Is it the dz Holley? 2 corner idle carbs with big cams have notoriously been fat. When the motor is cold, it can use the fuel, when hot it is pig rich.
How far out are the mixture screws? Turn them in and see what happens
69 Copo 9560 ZL-1 automatic [email protected], 1.95 on f70-14 polyglas F.AS.T. Race June 2016
69 Copo 9560 ZL-1 4spd [email protected] 1.93 60ft on F70/14
PSMCDR 2014
71LS6 vette [email protected] PSMCDR 2012 SOLD
1971ls6 is offline
post #6 of 22 (permalink) Old Apr 12th, 19, 06:13 AM
Gold Member
Todd
Chuck;
Just my 2 cents worth.
I struggled as you to get a proper tune. Gave up seat-o-the-pants tuning and bought a wideband dual O2 sensor set-up.
Made a huge difference just a few posts here: Tuning a 4053 with AFR
Todd
69Z
VI018DZ is offline
post #7 of 22 (permalink) Old Apr 12th, 19, 06:23 AM
Gold Member
Todd
Chuck;
FYI my secondary idle stop had my secondaries closed too much to get the trim screws adjusted for a proper idle.
I'd start there but tough to do without a O2 sensor.
Todd
69Z
VI018DZ is offline
post #8 of 22 (permalink) Old Apr 12th, 19, 06:58 AM Thread Starter
Chuck
Hey folks, thanks for the ideas..
1. I have the mixtures set where it runs best-smoothest-ish
2. The points and condenser are new, and has had the same issue with the old ones.
3. The coil....I will give that a try.
4. I don't have headers, but I wish I did, as I have a neighbor I'd love to annoy.
5. Carb is now off, but I will set floats again, same with secondary throttle plates.
6. PVC is good, and balancer is original as is the timing cover tin.
As I said, runs fine for first 15 minutes, then runs poorly at idle and will die at stops. Will restart but requires WOT to do so.
I will advise any solutions found....and I do plan on putting on a new correct exhaust system next month.
Thanks again!!
ChuckD is offline
post #9 of 22 (permalink) Old Apr 12th, 19, 09:00 AM
Matt
Chuck, just a thought, but requiring WOT for a hot restart might be vapor lock or fuel percolation in the bowls. This has happened to me in the past with Holley carburetors. Just something to think about.
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is offline
post #10 of 22 (permalink) Old Apr 12th, 19, 10:07 AM
Since a mouse came out of the exhaust, what else is in there? A friend had a 64 El Camino that sat for a while. It would never run right. Took the exhaust off and found about 10 pounds of dry dog food that the mice had carried up there.
cam67 is offline
post #11 of 22 (permalink) Old Apr 12th, 19, 10:46 AM
Thanks again!!
You ever consider running a Pertronix,, or similar, ignition vs a P&C??
FWIW I use one of these under carb to minimize/eliminate vapor lock.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
SoCal805 is offline
post #12 of 22 (permalink) Old Apr 12th, 19, 02:02 PM Thread Starter
Chuck
Once again, thanks for the advice! I plan on cutting open the exhaust system, and we'll see what archaeological finds there are! Also, I have an Edelbrock composite -blue spacer/insulator, so that will go on next month also. An updated ignition is also under consideration. Thanks and keep the ideas coming.
ChuckD is offline
post #13 of 22 (permalink) Old Apr 12th, 19, 08:37 PM
Gold Member
Todd
Didn't here you say what power valves you have and secondary throttle opening? Again trim screws will be ineffective and hot idle runoff without proper setting check those first before you install that carb. I had to pull mine a few times to get the secondary opening to where idle trims become effective. Cured all but very hot day runoff.
Tune for proper idle is tough again without O2.
69Z
VI018DZ is offline
post #14 of 22 (permalink) Old Apr 13th, 19, 01:25 PM
frank
Car stalls at stop sign and runs rich........ consider changing the needle and seats and then readjust the floats.
wot
frankk is offline
post #15 of 22 (permalink) Old Apr 13th, 19, 01:46 PM
bob
My 67 has a Mallory Unilite ignition system on it (1991 vintage) and found that the module was dying on it and caused similar issues. The car would run fine when the engine was cold, but once it warmed up; it wouldn't idle, starting a hot engine required the gas pedal on the floor as it is was flooded and basically would run like crap below 2,000-2,500 erpm. The issues themselves started after getting stuck in traffic for about 30 minutes (stop & go type traffic).....
I figured out the issue after swapping complete distributors with my truck at the time. Dropped the car one into my truck and it ran like crap, then took the truck distributor and put it in the car and it was beautiful running car again. I then called Mallory in NV and they had me send the distributor to them for a free repair. When they sent me distributor back it had a new module and a ton of dielectric grease under it.
Might be worth looking into the distributor.....
bob15 is online now
We're Here to Help-Sticky Ccass Exhaust and Headers 5 Oct 2nd, 19 08:06 AM
exhaust system bills69 Exhaust and Headers 8 Mar 27th, 19 03:19 AM
1968 Original Style Exhaust System 6 Cylinder SOA-Nova Restoration Corner 1 Apr 21st, 18 07:45 AM
Gibson American Muscle Exhaust System for Camaro + Promo! carid CARiD.com 0 Feb 15th, 18 05:09 AM
Dual exhaust equipped from factory ??? daven1256 Restoration Corner 16 Dec 1st, 17 11:32 PM
