no oil pressure - Team Camaro Tech
 1Likes
  • 1 Post By SoCal805
post #1 of 12 (permalink) Old Apr 14th, 19, 10:59 AM Thread Starter
Bill
no oil pressure
just woke up camaro 355 out of hibernation ,primed engine for oil pressure before start up and gauge does not show any pressure , quick start up fires right up and no pressure on gauge "sounds ok "
was fine when parked in the fall
guessing on trying new sender and gauge first?
bills69 is online now
post #2 of 12 (permalink) Old Apr 14th, 19, 11:04 AM
bob
Re: no oil pressure
It sounds like you have an electric gauge, can you install a mechanical gauge to first confirm you have oil pressure? What brand/model gauge?
bob15 is offline
post #3 of 12 (permalink) Old Apr 14th, 19, 01:30 PM Thread Starter
Bill
Re: no oil pressure
electric autometer
just the though of the oil tubes for gauges leaking in the console lead me to electric
post #4 of 12 (permalink) Old Apr 15th, 19, 03:38 AM
Kevin
Re: no oil pressure
You could pull off a valve cover and see if the rockers and surrounding areas have oil. This would quickly tell you that the oil is being pumped up the push rod tubes and onto the rockers, indicating oil pressure.
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
post #5 of 12 (permalink) Old Apr 15th, 19, 07:58 AM
Re: no oil pressure
I would suspect the sender....or wiring to it or gauge is bad.
FWIW I "T" off the rear oil port and used both OP senders (stock & Autometer) and kept the dash light function .in case one or the other FU.
If you have your stock sender and the wire is still there, swap out the autometer sender to see if the light comes on
you sure no critters got in your wiring during hibernation??
oldschoolchevy likes this.
SoCal805 is online now
post #6 of 12 (permalink) Old Apr 16th, 19, 06:00 AM Thread Starter
Bill
Re: no oil pressure
took out the sender and gauge all tested good back in car now works fine?
go figure
post #7 of 12 (permalink) Old Apr 16th, 19, 06:40 AM
69-Pace's Avatar
Re: no oil pressure
Sounds like it lost its ground over the winter.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #8 of 12 (permalink) Old Apr 17th, 19, 04:13 AM
Kevin
Re: no oil pressure
This. If you used an excessive amount of Teflon tape or other thread sealer, the sender may not have been grounded good at its mounting hole in the block.
bucko is offline
post #9 of 12 (permalink) Old Apr 17th, 19, 04:54 AM
DT
Donny
DT's Avatar
This. If you used an excessive amount of Teflon tape or other thread sealer, the sender may mot have been grounded good at its mounting hole in the block.
X2. I actually had to run a ground wire to my sender on my LS.
DT is offline
post #10 of 12 (permalink) Old Apr 17th, 19, 08:00 AM
Re: no oil pressure
ironically instructions with the gauges say to use Teflon tape on sender threads....but to much can "seal off" the ground contact
post #11 of 12 (permalink) Old Apr 17th, 19, 10:07 AM
Kevin
Re: no oil pressure
I stopped using Teflon tape for these grounded senders, and started using a smear of white pipe dope. I make sure the stuff is inside the threads, and that the threads themselves are shiny, making for a good contact.
When I did use the Teflon, I only wrapped the lower quarter inch; to do this, I cut the half inch tape in half. This allowed for at least two or three of the upper threads of the sensor to be exposed, and to make for a clean contact.
bucko is offline
post #12 of 12 (permalink) Old Apr 18th, 19, 06:24 AM Thread Starter
Bill
Re: no oil pressure
was installed 10 years and no issues , just one of those things that happen
Oil pan gasket blown out - pressure? pittpens24 Engine 25 Jun 5th, 19 04:49 AM
ls swap. oil pressure gauge not working DT Electrical & Wiring 8 Aug 21st, 18 06:59 AM
Changing oil and a filter tp_smith Bench Racing 3 Aug 13th, 18 09:55 AM
Oil Pressure Gauge Conversion SS-Scotty Electrical & Wiring 7 Jan 27th, 18 01:41 PM
Can Not Find Oil Pressure Gauge Adapter Brettallen59 Camaro Tech 16 Nov 28th, 17 12:44 PM
