DIY Valve Cover Studs - Team Camaro Tech
 2Likes
  • 2 Post By Moonpie
post #1 of 6 (permalink) Old Apr 14th, 19, 01:30 PM Thread Starter
Mickey
Moonpie's Avatar
Here's a quick n easy project that will work for any small studs you'd like to make in the garage. I made a set of valve cover studs in less than two hours time for my big block.
I bought 14 two inch 1/4 - 20 bolts. Using a dremel with a cutoff wheel I then cut them all to 1 5/16. I counted threads to try and make them all the same length. After de-burring the cut edges I double-nutted the studs and tightend them down into the heads.
I used wiz nuts or more technically, serrated flange lock nuts, for tighteners. I cut these about a quarter inch longer than necessary to be able to use chrome acorn nuts over the lock nuts for appearance sake.
ID:	226475   Click image for larger version
ID:	226477   Click image for larger version
Name:	Finished studs.jpg
Moonpie is offline
post #2 of 6 (permalink) Old Apr 14th, 19, 01:37 PM
Robert
Re: DIY Valve Cover Studs
That's nice, but you they make studs for big blocks, just curious why did you make yours?
https://www.ebay.com/itm/Big-Block-C...2-427-454-468/
1969 Camaro RS Hugger Orange - Work in Progress - You see rust, I see restoration!
rsb0719 is offline
post #3 of 6 (permalink) Old Apr 14th, 19, 01:42 PM
kevin
I have did almost the same. I took a 4" stainless bolt, then a 5/8" ss washer and cut in half then had it tiged to the head of the bolt
flat tire is online now
post #4 of 6 (permalink) Old Apr 14th, 19, 01:56 PM
Brett
I like these. They are ARP! (rib, rib Kevin) Honestly, I think the big box stores (Home Depot, Lowes) should have some Allen set screws that don't have a head on them, it's just basically all-thread. That way, you wouldn't have to cut the heads off and deburr the threads.
Brett.....
Rockets Up In 2020!
Brettallen59 is offline
post #5 of 6 (permalink) Old Apr 14th, 19, 02:34 PM
Jon
X2 on the allen socketed set screw/running thread. Have a couple of boxes of them left in my basement from my drag racing days, maybe 50 or so.
Jon N
dyno jonn is offline
post #6 of 6 (permalink) Old Apr 14th, 19, 09:09 PM Thread Starter
Mickey
Moonpie's Avatar
Originally Posted by rsb0719 View Post
That's nice, but you they make studs for big blocks, just curious why did you make yours?/
For the sheer joy of doing it myself , being able to stand back and say, "Hey that ain't half bad!"
rsb0719 and Melrose RS like this.
Moonpie is offline
Oil pan gasket blown out - pressure? pittpens24 Engine 25 Jun 5th, 19 04:49 AM
Valve cover gasket installation to glue or not to glue? Niblet Engine 19 Oct 31st, 18 07:03 PM
Z-28 Valve Cover? The Camaro Guy Engine 6 Oct 9th, 18 09:02 PM
Are jets my next step? 4Speed67CamaroRS Engine 19 Apr 10th, 18 10:37 AM
Rubber vs cork valve cover gaskets JohnnyD Engine 13 Jan 18th, 18 07:58 AM
