Small diameter HEI Distributor - Team Camaro Tech
 5Likes
  • 1 Post By 69Z28
  • 1 Post By bucko
  • 1 Post By Luwi67
  • 1 Post By Dave69Z
  • 1 Post By Milt's 68 SS/RS 396
post #1 of 9 (permalink) Old Apr 23rd, 19, 10:18 PM Thread Starter
Hey guys - I just put in a new motor in my Camaro from Blueprint engines. I have an HEI distributor that I purchased from Summit, but it won't clear the firewall. Does anyone know of solutions like a smaller diameter HEI? Has anyone fit a conventional HEI on a '68 and if so, how? Only thing I can think of is to dent the firewall.
Thanks for any/all help.
1968 Convertible, 355 ci 400 hp Blueprint sbc engine, 600 cfm Edelbrock, Performer intake, 4L60E, 10 bolt, 3:08
Troutslayer is offline
post #2 of 9 (permalink) Old Apr 24th, 19, 12:03 AM
Gary
69Z28's Avatar
Re: Small diameter HEI Distributor
If your looking for a stock look, I've been using a DAVES Small Body HEI for close to 10 or so years. He's a member here. DAVE RAY. I like what he does. You can also build your own. Probably what others will tell you, Pertronix or something else.
This link keeps timing out for some reason, not sure why. https://www.davessmallbodyheis.com
Troutslayer likes this.
06A 1969 Camaro Z28 711 69 B Black Stripes Console w/tach and gauges
69Z28 is offline
post #3 of 9 (permalink) Old Apr 24th, 19, 03:38 AM
Kevin
I had a stock GM HEI on my 67 SBC (327). It cleared just fine. If its issues with being able to set the timing by rotating the distributor, and the ""bump" on the distributor cap is hitting the firewall, you can rotate the distributor to the left, and simply use a different "number one" spark plug position. Then follow the correct firing order for the remainder of the spark plug wires to spark plugs.
If this is a SBC engine, it should have clearance, unless the 68 has some sort of different firewall that the 67's did not have.
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
post #4 of 9 (permalink) Old Apr 24th, 19, 06:49 AM
DT
Donny
DT's Avatar
I had one on my 396. It was close, but didn’t hit.
DT is offline
post #5 of 9 (permalink) Old Apr 24th, 19, 07:43 AM Thread Starter
Thanks everyone. Much appreciated.
post #6 of 9 (permalink) Old Apr 24th, 19, 05:12 PM
scott
68basecoupe's Avatar
I had to “ dimple” the firewall to get enough clearance to be able to adjust the timing on my 327
68basecoupe is offline
post #7 of 9 (permalink) Old Apr 25th, 19, 08:19 PM
Bobby
I think Pertronix makes a high output distributor that looks like an original.
https://pertronix.com/stocklookbydis...Chevrolet#auto
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180° Headers
black/black
no radio
Luwi67 is offline
post #8 of 9 (permalink) Old May 10th, 19, 10:17 AM
I have a Davis unified small bod Hei and its worked flawlessly for 5 years now. Way better than the Msd stuff ever did. Good Luck
Dave69Z is offline
post #9 of 9 (permalink) Old May 10th, 19, 09:57 PM
Milt
Milt's 68 SS/RS 396's Avatar
I have a GM HEI on my big block currently. It's a tight fit but it works. I did er, adjust the fire wall on another engine years ago.😳
Go big, or stay Home!
Milt's 68 SS/RS 396 is offline
Hei distributor no spark LP Engine 4 Dec 31st, 18 04:28 PM
Tdc? SoCal805 Engine 8 Dec 3rd, 18 06:14 AM
Are jets my next step? 4Speed67CamaroRS Engine 19 Apr 10th, 18 10:37 AM
ZZ502 melonized distributor gear excessive wear Gyrine Engine 10 Feb 12th, 18 01:48 PM
