Compression and leakdown test results - good? - Team Camaro Tech
 2Likes
  • 1 Post By DOUG G
  • 1 Post By Sam 15
post #1 of 5 (permalink) Old Apr 27th, 19, 09:12 AM Thread Starter
Greg
pittpens24's Avatar
Never performed either of these tests before and believe the results are good from what I've read, but would love confirmation. My engine builder wanted me to run these tests because I blew my oil pan gasket and he was afraid of excessive bottom end pressures. Here are the results:
Compression:
1 - 190psi
2 - 190psi
3 - 190psi
4 - 190psi
5 - 190psi
6 - 180psi
7 - 190psi
8 - 190psi
Leakdown:
1 - 6psi
2 - 6psi
3 - 6psi
4 - 7psi
5 - 7psi
6 - 6psi
7 - 6psi
8 - 5psi
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #2 of 5 (permalink) Old Apr 27th, 19, 09:27 AM
Re: Compression and leakdown test results - good?
I have seen customer's fresh rebuilds with more variannce between cylinders. Ring seal isn't the issue.
Big Dave
Larger Dave is online now
post #3 of 5 (permalink) Old Apr 27th, 19, 09:45 AM Thread Starter
Greg
pittpens24's Avatar
Thx Dave!
Moser 9" with 4:11
572 BB - CM Engines
post #4 of 5 (permalink) Old Apr 27th, 19, 07:57 PM
Looks great to me
pittpens24 likes this.
68 Camaro~LSx ~all motor
post #5 of 5 (permalink) Old Apr 28th, 19, 08:41 AM
Rick
[QUOTE=pittpens24; My engine builder wanted me to run these tests because I blew my oil pan gasket and he was afraid of excessive bottom end pressures. [/QUOTE]
Check your PCV and breather(s).
Everett#2390 likes this.
Sam 15 is offline
