1969 Camaro EFI Gas Tank Question - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 28th, 19, 12:18 PM Thread Starter
Joe
HI,
I am doing an EFI conversion on my Camaro and I wanted to ask if any knows of a 1969 Camaro gas tack that has a 3" opening for the sending unit.
The sending unit and pump that I have needs a larger opening than the standard gas tank.
Any help appericated
1969 Camaro V8 Base Model, Black w/White Rally Stripes, 350 HO w/ FiTech Go 4 600, HEI, 700r4 trans, 10 Bolt 4:10 Rear End, 15" Rally Wheels, 245/60/15 Rear, 235/60/15 Front
Non stop fun from 0 to 90 mph!
BadCo69 is offline
post #2 of 5 (permalink) Old Apr 28th, 19, 07:04 PM
Simon
Re: 1969 Camaro EFI Gas Tank Question
Rick's tanks look like there is enough material to enlarge the existing sending unit opening a bit larger?
1969 Chevy Camaro and Pontiac Firebird Fuel Tank - For Fuel Injection
slazisme is offline
post #3 of 5 (permalink) Old May 1st, 19, 11:43 AM
Not sure of its opening, but the tank I got from Tanks Inc holds a modern fuel pump/sender assembly.
Muadi is offline
post #4 of 5 (permalink) Old May 10th, 19, 10:02 PM
Milt
Milt's 68 SS/RS 396's Avatar
This is what I ran on my conversion and it works great in the stock tank.
https://www.holley.com/products/fuel...s/parts/12-300
Go big, or stay Home!
Milt's 68 SS/RS 396 is offline
post #5 of 5 (permalink) Old May 11th, 19, 05:18 AM
Vega$69's Avatar
Nice set up. Its a Walbro pump. The same pump that Tanks used . The included built in FPR with no return line is neat.
Good option and can use your OEM tank. You will still need an in-line fuel filter.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
Tags
efi, gas tank
Pressure in vented Tanks Inc gas tank causing it to leak pittpens24 Camaro Tech 32 Sep 21st, 18 01:26 PM
Gas tank vent line question hawk48rq Engine 1 Jul 26th, 18 04:15 PM
1969 camaro with ac evaporator box to enter box Hardware question camaro69ss572 Restoration Corner 4 Jun 23rd, 18 09:18 PM
