A few more EFI Fuel Questions... - Team Camaro Tech
post #1 of 1 (permalink) Old May 12th, 19, 10:43 AM Thread Starter
Rob
robsutt's Avatar
Iím installing the tanks inc kit in my 68 RS Vert. Also installed in the complete new American wire harness. Using tanks inc LS rubber fuel hose kit too with Vette regulator.
1) Vent. From searches it appears you canít get it higher than the filler neck. Any one found a way? If not whereís the highest location I should try?
2) Relay. Seems neither the wire kit nor tanks inc ďcompleteĒ kits come with one. Should I go buy late model vette relay or does it matter?
3) Regulator location. Seems most install it near the pump for less lines to run. Are there any areas to avoid putting it or issues with it too close to the pump? I imagine just not so close the rubber lines kink.
4) Pad on top of tank. Iíd rather not buy the $20 tank mount rubber / foam kit. Any suggestions of a good material to use to replace that rectangular foam pad thatís supposed to be there?
Thanks!
1968 RS Conv - My Build Thread:
robsutt is offline
Amount of fuel needed to feed a 540 540 RAT Performance 3 Nov 15th, 07 12:54 PM
406 Fuel Pump Questions / Recommendations satz28 Engine 4 Jun 19th, 07 07:47 PM
Fuel Cell Vs Stock Tank For Efi Pros Cons? mark67ss EFI in your modern Classic 7 May 26th, 07 09:47 PM
fuel cell/sump/electric pump for high pressure EFI 69MyWay Engine 4 Aug 15th, 04 12:29 PM
efi fuel pump mounting jblakes Performance 7 Jun 24th, 04 05:26 PM
