what is this hole/gap between block and head? - Team Camaro Tech
post #1 of 5 (permalink) Old May 13th, 19, 04:54 PM Thread Starter
Joe
I pulled my 350 out of the car for some cleanup and upgrades. When I was driving the car, had oil leaking rear driver side at the head/block/china wall intersection. I was able to seal it up. What is supposed to be in this hole? (picture 1)The block was built in 1975 and see the second picture for the drivers side head info. I think it reads 333882. GM2T.
FYI: The passenger head is 333882. GM 1T.
Sent from my SM-G930T using Tapatalk
1967 Camaro RS 350, muncie
1970 Chevelle 454, 200 4r
jcor12 is offline
post #2 of 5 (permalink) Old May 13th, 19, 05:39 PM
Re: what is this hole/gap between block and head?
Oil channel and should have a plug in it...or a sending unit.
Is there a plug ? (hope so, otherwise it would be a lot more than a drip)
If there is a plug, it wasn't sealed well <---most likely culprit.
68 Camaro~LSx ~all motor
post #3 of 5 (permalink) Old May 13th, 19, 07:22 PM Thread Starter
Joe
Doug, yes I can see the plug in there. I guess the sealant/gasket must have come off in that area.
jcor12 is offline
post #4 of 5 (permalink) Old May 14th, 19, 07:44 AM
No gasket. Pipe dope (same as used by plumbers before plastic took over the world). It is a pipe thread in the block that is sealed by a pipe plug. must have sealant to prevent oil from wicking (slow leak) up between the threads.
Big Dave
Larger Dave is offline
post #5 of 5 (permalink) Old May 14th, 19, 06:08 PM
Big Dave
Thinking he meant gasket maker (AKA: RTV) ?
But yes, pipe dope. (doesn't have to be GM brand )
Can be bought at your local parts store, big box store (home depot/lowes/ETC)
head bolts flat tire Engine 2 Feb 2nd, 18 12:53 PM
Profilers 195 vs. Afr 195 Big Mike41 Performance 183 Nov 15th, 10 06:11 PM
Big block with brown valves dynaflash Engine 2 Jul 13th, 10 09:25 AM
BBC question lazyone Engine 3 May 6th, 10 03:24 AM
Warped Head, Blown Gasket, Cracked Block? A69CamRSFrk Tech 2000 8 Jan 3rd, 00 07:28 PM
