Signs of valve float or fuel starvation? - Team Camaro Tech
post #1 of 11 (permalink) Old May 15th, 19, 07:15 PM Thread Starter
Arch Stanton's Avatar
Doing some fine tuning on the 350.
I'm getting some light to med sputtering at high rpms, around 4800 and up.
Just wondering what some quick way to tell if I'm running the bowls dry or it I don't have enough valve spring pressure? When should this cam be done? Comp says 1500-5500.
SBC 350
9:1
Performer RPM non air gap
Holley 600 v.s. (1850)
Mech fuel pump- Z28 spec supposedly
Orig 327 2 bbl fuel lines.
ported 041 heads with 2.02/1.6
1 5/8 headers
Comp HE268, 218 @ .050 and .483 lift (1.6 rockers)
TH350 with 2000 stall t/conv (Hughes GM20)
3.55 gears
26" tire
I have a valvespring pressure checker, and have on eof those cheap vacuum/fuel pressure gauges I think I can plumb in and tape to the windshield and do a run while checking it I guess, but was hoping for what is more of telltale signs of either fuel or valvespring.
Hope I described what I'm trying to check out......
- John
Misfit tortured soul. Lone wolf. Unicorn.
'67 V8 Camaro - 12637, 797-Z (Parchment), M-M (Royal Plum), 2M, 3K, 5Y
Arch Stanton is offline
post #2 of 11 (permalink) Old May 15th, 19, 07:57 PM
keith
X-77 keith's Avatar
5/16 fuel line? Kinda small for what you are describing in my opinion. Could be almost anything though.
X-77 keith
X-77 keith is offline
post #3 of 11 (permalink) Old May 15th, 19, 09:07 PM
Beth
Re: Signs of valve float or fuel starvation?
Did you put those bigger valves in with the old springs ?
More weight and old tired springs ; not a good combo.
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #4 of 11 (permalink) Old May 15th, 19, 11:04 PM
scblucam's Avatar
Points?
68 302 M20 - 85 IROC Z
scblucam is offline
post #5 of 11 (permalink) Old May 16th, 19, 05:00 AM Thread Starter
New springs when new valves were put in. Valve guides too. Actually they were completely gone through. Seats, hot tanked, slightest milling just to get them flat......
Performance distributors DUI HEI distributor. I hate points.
- John
post #6 of 11 (permalink) Old May 16th, 19, 08:40 AM
I would rule out fuel delivery (pressure) problem first.
Hook up a FP gauge and tape it to windshield and go for a sustained WOT run, especially hitting 5k rpm,....if FP drops than that is your issue. If not than valve springs are suspect
most cam cards spec a spring but with using 1.\:5 ratio RR so when going 1:6 you need to do the math to confirm you are still within the springs "bind height" measurement. Your cam lift is not extreme but confirm your springs are up to spec
SoCal805 is offline
post #7 of 11 (permalink) Old May 16th, 19, 09:24 AM
Darin
ilikeike's Avatar
Secondaries opening ?
Primary only on that 600 my not let the engine go 4000+ Under load.
Just a thought.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #8 of 11 (permalink) Old May 16th, 19, 11:44 AM
Jon
No special equipment is needed to check for valve float. All you need is the tachometer you already have. Best way is to have the vehicle inside where other noises don't interfere with the diagnosis. All you have to do is slowly bring the engine up to and over the RPM where you are experiencing the problem. If you have valve float, you will notice the exhaust note changing when you reach that point.
Jon N
dyno jonn is online now
post #9 of 11 (permalink) Old May 16th, 19, 05:04 PM Thread Starter
Cool. These are what I was thinking.
I'll try these out. Thanks.
- John
post #10 of 11 (permalink) Old May 17th, 19, 03:48 AM
Kevin
Are you absolutely sure the sputter at 4800 RPM is not ignition related? You may be chasing the rabbit in the wrong hole in thinking its fuel or valve spring issues.
If the distributor is using a box (MSD) with a rev limiter, that could be an issue. Or the module within the distributor is breaking down at higher RPM.
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
post #11 of 11 (permalink) Old May 17th, 19, 04:55 AM
spark plug gap
spark plug wires
cap/rotor
Above are the places I'd look first.
68 Camaro~LSx ~all motor
Tanks Inc EFI Fuel System Install Vega$69 Camaro Tech 67 Nov 23rd, 16 01:34 PM
New solid roller ordered. Whew Fred Ficarra Performance 948 Jan 21st, 12 03:58 PM
Fuel starvation ??? Sctthys Troubleshooting 6 Sep 6th, 11 08:48 AM
Interesting engine concept onovakind67 Engine 76 May 11th, 10 11:00 PM
Powerglides yellowrallys Transmission & Driveline 15 Sep 14th, 07 08:55 AM
