valve cover clearance 427 BB - Team Camaro Tech
post #1 of 14 (permalink) Old May 18th, 19, 05:57 PM Thread Starter
stevo camaro's Avatar
Unhappy valve cover clearance 427 BB
So I get the motor back from the machine shop. He used Scorpion roller rockers. I didn't have an issue with that until now. Valve covers won't fit. Any valve cover. You can see the problem in the pics. Just one rocker on each head interferes with any valve cover. So my question is, would it hurt to clearance the 2 rockers at the corner edge? You can see by the pic where I'm talking about. Any thoughts? I REALLY don't want to have to buy another set of rockers. She still doesn't understand why I'm changing motors to begin with. LOL
ID:	227067   Click image for larger version
67 RS 327, 4-speed, posi, done.
67 Modified, 454, TH-400, posi, under construction.
67 SS 396, 4-speed, basket case.
72 RS, sitting, partially done.
55 210 post, 2 door, 327 4-speed runs good.
55 2 door post, gasser project
69 Cadillac ElDorado
69 4x4 suburban
59 ElCamino
Some mornings, it's just not worth chewing thru the leather straps"
stevo camaro is offline
post #2 of 14 (permalink) Old May 18th, 19, 06:12 PM
Brandon
Re: valve cover clearance 427 BB
Because of the Proform 1.6 roller rockers I had used on mine. I had to go with tall valve covers which were a pain when it came time to pull the drivers side. I just swapped out my old 462 heads for a set of jegs 514022 aluminum heads. Checked the clearance and with still using the 1.6 RR I was able to purchase these https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1. and the fit is excellent with enough clearance under the windshield wiper motor that I don't have to finagle them to get the drivers out.
Brandon J. licence 1NASTY67
Nantooch is offline
post #3 of 14 (permalink) Old May 18th, 19, 06:39 PM Thread Starter
Looks nice. My issue is bolting any valve cover on the head. I have 5 different sets and styles at the shop. Height clearance is not the issue. That one rocker is hitting the side of all of the valve covers. Right where the indentation has to be. It's not hitting by much. I was thinking of grinding off the corner of the rocker a smidge. Wondering if anyone has done this before. And if it was OK afterwards.
69 4x4 suburban
59 ElCamino
post #4 of 14 (permalink) Old May 18th, 19, 08:36 PM
Lyle
I took some material off the corner of one or two of my gold race rockers on my 454. I have tall covers too. I have had no problems.
akwolf is offline
post #5 of 14 (permalink) Old May 18th, 19, 09:02 PM
Brandon
I think I would worry more about hitting the ridge on the head than on the valve cover. I don't believe that rounding out that corner will weaken the rocker body at all. If I may ask, why did they go with 1.7s. Seems a bit extreme, but I did go with 1.6s?
Nantooch is offline
post #6 of 14 (permalink) Old May 18th, 19, 09:19 PM
Lonnie
Lonnie P's Avatar
1.7 ratio is standard on a big block.
Lonnie P is offline
post #7 of 14 (permalink) Old May 18th, 19, 09:28 PM Thread Starter
The decision to go with 1.7s was my engine builders. I left those decisions to him because being old, and working 12-13 hr. days, I try to preserve whats left of my brain. Which isn't much. LOL Remember, I'm talking about a big block 427.
Was that to clear the same issue I have? The rockers have so much meat on them, I'm thinking that taking a little bit off the corner shouldn't be an issue. I think a 16th off the corner. Given the fact that the machine shop bought them, I doubt I could exchange them for another style. And that would be guaranteed if I grind them. LOL
Anybody else have clearance issues with these? Scorpion 1.7s.
69 4x4 suburban
59 ElCamino
post #8 of 14 (permalink) Old May 19th, 19, 07:14 AM
scblucam's Avatar
My thought is Your builder didn't see that? I assume it has not been run?
68 302 M20 - 85 IROC Z
scblucam is offline
post #9 of 14 (permalink) Old May 19th, 19, 07:30 AM Thread Starter
No, the motor hasn't been run yet. And yeah, I'm surprised he didn't see that also. Seems like everytime I trust someone to make a decision that I should be making, it bites me in the ***.
So I'm having the torque converter built in redding cal. locally. A 28-3000 stall. They can do it for $450. VS $550+ for others. He's trying to convince me that a 10" converter will perform better that a normal size converter of the same stall speed. Wouldn't the 10" produce more heat? It's a street car, I'm not racing it. Another decision I'm worried about leaving to someone else.
Your thoughts?
69 4x4 suburban
59 ElCamino
post #10 of 14 (permalink) Old May 19th, 19, 07:56 AM Thread Starter
OK. Breaking news. LOL After going to Scorpion rockers homepage and looking up the part no. It seems they have specially machined 2 rockers for #1 and #8 to clear the valve cover on 396-502 mark IV's. So I'm going to look for those 2 rockers that are probably stuffed on some other valve in the head. Whew, this may be the fix right in front of me. LOL I'm feeling a little better, not much, but a little. LOL
And I will be calling the engine builder about at least GLANCING at instructions of after market performance parts applications. Dammit! LOL
69 4x4 suburban
59 ElCamino
post #11 of 14 (permalink) Old May 19th, 19, 08:17 AM
Lonnie
Lonnie P's Avatar
For the converter, smaller is usually better.
Smaller converters typically stall higher due to their reduced circumference, whereas a larger converter often has a reduced fin angle which contributes to additional slippage & reduced lockup at higher speeds.
Plus a lighter, small converter can also help with performance.
Keep in mind 2 converters for 2 different manufacturers can be totally different.
The physical design & quality of the part can make a world of difference.
Lonnie P is offline
post #12 of 14 (permalink) Old May 19th, 19, 09:25 AM
OP
Ideally you can find/swap the 2 RR that, according to your note from Scorpion, are cast smaller to clear BB applications and relash the valves.
Aluminum bodied RR are bulky compared to steel (Comp Ultra Pro Mags). IMHO Scorpion are more a budget RR. I know several Cobra guys who have 427 SB motors had them break.
Hope your builder checked PR length....might want to take a Sharpie and mark one of the valve tips, install/lash RR and rotate engine twice by hand, remove that RR, check witness mark on valve tip since you will be swapping a few RR anyway. It wants to be centered on the valve tip. Pattern closer to intake side wants a longer PR. Pattern closer to exhaust manifold wants to be shorter. They make adjustable PR check tools for about $10
2800-3000 stall converter...regardless of size you will need a external tranny cooler. Good idea to run a tranny temp gauge with high stall converters. IDK how big a cam you have but 2400 stall may be more street friendly
SoCal805 is online now
post #13 of 14 (permalink) Old May 19th, 19, 03:09 PM
Morgan
No issue at all grinding of the 2 corners, I did it on a set of Harland park rockers and never had a problem
69 Copo 9560 ZL-1 automatic [email protected], 1.95 on f70-14 polyglas F.AS.T. Race June 2016
69 Copo 9560 ZL-1 4spd [email protected] 1.93 60ft on F70/14
PSMCDR 2014
71LS6 vette [email protected] PSMCDR 2012 SOLD
1971ls6 is offline
post #14 of 14 (permalink) Old May 19th, 19, 06:19 PM Thread Starter
Well, here's the solution. Putting the right rocker on the right valve. LOL The "pre-machined" rockers belong on the #1 & #8 intake valves. I found them on the #5 and #7. It's going to be enough clearance for the valve cover to bolt on now. Thank god.
Yes, the push rod length was checked and they are shorter than stock.
Yes, I am running an external trans cooler.
Glad to hear that aluminum rockers can be ground on if needed without destroying a set.
I'm going to go with the 10" 2800-3000 stall converter, it was highly recommended by the cam grinder. I had it custom ground by Bullit cams for the tunnel ram and power brakes. LOL
ID:	227099   Click image for larger version
69 4x4 suburban
59 ElCamino
Big Block Chevy Solid Roller Adjustment Help wthurrott Performance 18 Oct 16th, 14 02:08 PM
Chevy valve adjustment? car wont go under load dawg Troubleshooting 13 Jan 7th, 13 05:23 AM
New solid roller ordered. Whew Fred Ficarra Performance 948 Jan 21st, 12 03:58 PM
BBC Valve Cover Clearance chevyssman Engine 4 Feb 19th, 10 09:07 AM
Powerglides yellowrallys Transmission & Driveline 15 Sep 14th, 07 08:55 AM
