Hesitation - '67 Camaro 396CI - Team Camaro Tech
post #1 of 9 (permalink) Old May 28th, 19, 01:47 PM Thread Starter
Andrew
Andrew69's Avatar
Over the winter and through the spring I have performed some suspension and performance upgrades to this '67 Camaro convertible. It has an unknown year 396 with Quadrajet 4-barrel (carb is from a 1975 Chevy truck) with a new 4L60 transmission and a new 3.55 geared 12-bolt rear.
A couple of months ago during acceleration the engine would stall like it was starving for fuel. I had noted earlier when installing a new fuel tank and fuel sending unit the fuel filter on the old sending unit had disintegrated with some strands remaining. This car had an inline fuel filter before the mechanical pump so I figured it was probably full of residue from the old pickup unit filter.
I replaced the fuel pump, removed the inline fuel filter and installed a fuel filter in the carburetor. My recent driving did not display any hesitation tendencies. I felt the hesitation problem was solved.
Today the brother of the car's owner came by to check things out. The owner lives out of town and due to distance he cannot visit. He drove the car for about 10 miles, sometimes aggressively, with no hesitation. We then we stopped to fill up with gas. During the fill up the car sat in the sun.
After re-fueling he began experiencing hesitation during spirited driving. Not super aggressive driving but feeling the pull of the engine.
It is 95 degrees today with no clouds and the humidity is low Really too hot for a convertible with top down but it was fun nonetheless. Could this car be experiencing vapor lock? Another thing I noted as I replaced the fuel pump this car has 5/16" fuel line from the fuel tank to the fuel pump. Should a 396 have 3/8" line? This 396 seems pretty stock with no thumpy cam and as stated the Quadrajet 4-barrel on a cast iron intake. Pretty basic for a big block, but for all I know it might be a 454 engine. There are no stampings on top by #2 piston, they may have been cut off when decking the block. I didn't concern myself with the 5/16" line because this is not a high performance engine. Are there some casting numbers somewhere on the block that might identify it?
Please school me on Quadrajets and how I might rectify this concern. If it were a Holly I would be checking float levels and maybe changing out the jets. I know very little about the workings of a Quadrajet.
I may drive the car again in cooler morning climate to see if I can repeat the hesitation. What do you Camaro experts think? If it is vapor lock how do I rectify it?
I am sorry for this wall of text but hope I clearly represented the concern.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #2 of 9 (permalink) Old May 28th, 19, 02:04 PM
Re: Hesitation - '67 Camaro 396CI
It's possible the accelerator pump on the carb needs to be replaced. It's fairly common
on quadrajets and not difficult to do. The carb could probably use a rebuild if it hasn't
been done for a while. I actually prefer quadrajets over just about anything else on these
old car engines.
my 67' build thread:
allanjs is offline
post #3 of 9 (permalink) Old May 29th, 19, 05:04 AM
As QAl suggests, remove air cleaner and check accelerator pump is pumping fuel.
Another item you could do is give it full time vacuum on vacuum advance and adjust dist for best running at idle.
Usually, advancing timing lessens hestiations. You should be able to go from idle to wide-open throttle, 5K rpms, in about 5 microseconds.
If it pings, decrease by 2 until gone.
Adjust carb with vacuum gauge. Speaking if vacuum gauge, a stock cammed engine should give 18-22 inches od vacuum at idle.
Any value less means aggressive camshaft.
Again, look at engine pad determining engine size & originality.
There is an air valve adjustment on pass side of airhorn for air valve opening rate, spring adjustment, and usually, one complete turn tensioning the spring gives smooth acceleration.
Doing a good job is like peeing in your dark pants you get a warm feeling, but nobody notices
post #4 of 9 (permalink) Old May 29th, 19, 10:17 AM Thread Starter
Andrew
Andrew69's Avatar
The accelerator pump on the carb is squirting when the pedal is pushed. It seems okay, but I haven't disassembled it.
This morning I took the car for a drive. On a country road I stopped and accelerated repeatedly and couldn't get the hesitation to kick in. The car ran great. Instead of returning home I stopped to visit a friend. After the car sat for about 15 minutes after leaving his driveway it again displayed the symptoms of vapor lock. Then everything returned to normal.
I think I can move the fuel line leading to the fuel pump further away from the header tubes and will wrap it with heat shield tubing. The hard line between the pump and the carb lays against the lower radiator hose and near the engine block and head. I'll try to bend it to allow more air gap. I'll let you all know the results.
Thanks for the input thus far.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #5 of 9 (permalink) Old May 30th, 19, 03:35 AM
Kevin
Originally Posted by Andrew69 View Post
...I think I can move the fuel line leading to the fuel pump further away from the header tubes and will wrap it with heat shield tubing. The hard line between the pump and the carb lays against the lower radiator hose and near the engine block and head...
That fuel line IMO would be a huge potential for inducing vapor lock, as it is getting some hefty heat from the lower radiator hose.
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
post #6 of 9 (permalink) Old Sep 8th, 19, 08:37 AM Thread Starter
Andrew
Andrew69's Avatar
I needed to come back with a follow up. I did massage the fuel line away from the header tubes and applied over it a fiberglass insulated. The vapor lock problems went away. It was this insulated sock that I purchased:
https://www.amazon.com/dp/B075M7H891...arosconvert-20
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #7 of 9 (permalink) Old Sep 8th, 19, 09:11 AM
Beth
I needed to come back with a follow up. I did massage the fuel line away from the header tubes and applied a fiberglass insulated sock over it. The vapor lock problems went away. It was this insulated sock that I purchased.
Great looking engine. I'm putting the same cast-iron hi-rise and a 78 q-jet on my 489 Chevelle. That intake was used on 427-390 hp vettes. A friend just dynoed a 550 hp BBC with that same intake.
There should be a 1/4" insulating spacer under that q-jet.
I ordered some of that insulation. Thanks
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #8 of 9 (permalink) Old Sep 8th, 19, 06:46 PM Thread Starter
Andrew
Andrew69's Avatar
It's interesting that the cast iron intake is desirable. That 396 engine was coded as from a '66 or '67 Chevelle. With that intake it ran pretty strong and would smoke the tires from a standstill without trans-breaking or anything. If it was still here I would check for the insulating spacer, but it's now back home. Between the tuning and changing the rear gears from 2.73 to 3.55 that car became really peppy.
The insulation sock isn't very expensive and really did help.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #9 of 9 (permalink) Old Sep 9th, 19, 10:24 AM
This product is very good for wrapping fuel lines or electrical that run near/on heat producing sources (engine/exhaust). It's split loom so no need to disconnect the line to install it. Comes in various widths
I got mine from Summit
https://vibrantperformance.com/catal...b46abdf7140e87
SoCal805 is offline
