396 in '67 Camaro, Identify Block Plz - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 1st, 19, 10:38 AM Thread Starter
Andrew
Andrew69's Avatar
Hello-
This '67 Camaro currently has a big block although the trim tag identifies it as SS 350 car. How do I identify the year model 396 or if it may be of greater displacement. There are no stampings by cylinder #2. Maybe this is a reproduction block or the block was decked. I don't know. It doesn't have a thumpy cam and drives really smoothly.
Using a mirror I can find no casting numbers but above the oil filter I find this info:
HI PERF
PASS
18
Does this narrow it down?
Thank you,
Andrew
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #2 of 4 (permalink) Old Jun 1st, 19, 11:14 AM
Re: 396 in '67 Camaro, Identify Block Plz
https://www.chevellestuff.net/qd/eng...mp_numbers.htm
Small Block Chevy Engine Block casting and code identification
[URL=https://s263.photobucket.com/user/tjs69_photos/media/location%20of%20engine%20numbers/endinedetail1.jpg.html][/UR
[URL=https://s263.photobucket.com/user/tjs69_photos/media/location%20of%20engine%20numbers/0-66-16-13.jpg.html][/URL
TJS69 is offline
post #3 of 4 (permalink) Old Jun 1st, 19, 12:46 PM Thread Starter
Andrew
Andrew69's Avatar
Okay, found some more numbers using a scope camera plugged into the computer. It seems to be 3902408.
Looking some more and enlarging that last picture I believe the last digit is a 6 not an 8. That means it is a '67 Chevelle 396. I've added another picture found on line of casting 3902406 including the letter P below the number.
Name:	Block Number.jpg
ID:	227395   Click image for larger version
Name:	Block Number 2.jpg
ID:	227397   Click image for larger version
Name:	Block Number 4.jpg
Name:	Block Number 5.jpg
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #4 of 4 (permalink) Old Jun 1st, 19, 12:57 PM
If the block was decked on a rebuild then the original numbers are lost. (They could be recovered if the block was etched with acid, but it isn't guaranteed, and the acid destroys that area of the block).
Date casting numbers are found on the rear step of the block in front of the bell housing. They are recycled every ten years so a date code can be for a 60, through an 80's series of blocks. 1984 was the last year a 402 (small bore BBC) was produced. If it is a one piece rear main seal it was cast after 1990 and the displacement was cast into the side of the block in big numbers (7.4 for a 454 block). If it has no provision for a mechanical fuel pump it is a Gen V, it it is a one piece rear main seal block and it does have a provision for a mechanical fuel pump it is a Gen VI block.
1974 was the last year a BBC was available in the Corvette or a full size Chevy car (1973 for everybody else), with the exception of pick-ups. After 1974 all BBC engines were only offered in a light truck, and the heads had a major redesign dropping port volume to increase low RPM torque called a "Peanut Port" head (note light truck oil pan will not fit in a car body and has to be changed, even on a crate motor from GMPP).
Block casting numbers that determine displacement (bore size) were cast next to the date casting in the same area on the back of the block. Two bolt or four bolt is determined by the amount of machine work, as all blocks are the same. Any two bolt block can be made into a four bolt by finding four bolt caps and having additional machine work done to the block (that is why four bolt or two bolt frequently apply to the same casting number, though there are some numbers that were four bolt only such as marine or truck blocks). In addition to having four bolt main caps a four bolt block was machined for an external oil cooler, used on trucks and Corvettes.
All Mark IV blocks are essentially the same from 1967 through 1990 with the different casting numbers reflecting bore size and changes made since 1967 to the block to reflect changes mandated by federal law for emissions requirement. Every change to the casting copes and molds generated another casting number even if it was just to cast a pad to have a hole drilled in the block for a sensor, or to remove casting metal from the bottom of the block to add a longer stroke crank.
All Mark IV blocks look alike alike on the outside; and are different only in casting numbers (1965-'66 had a different oiling system, and rear cam bearing reflecting the difference in how the upper half of the engine was oiled).
Since almost all BBC engines today came out of light trucks odds are you have a 402 or a 454 motor. Since few were around from 1984 odds favor a 454.
Big Dave
Larger Dave is offline
