BB lifter valley pan - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 4th, 19, 06:53 PM Thread Starter
stevo camaro's Avatar
I have the lifter valley pan out of the 396 and I was going to install it in the 427 but it doesn't look right to me with roller lifters. It looks like it would starve the lifters of oil since they stick up alot further than regular flat tappet lifters.
Should I leave this out of the motor with rollers?
67 RS 327, 4-speed, posi, done.
67 Modified, 454, TH-400, posi, under construction.
67 SS 396, 4-speed, basket case.
72 RS, sitting, partially done.
55 210 post, 2 door, 327 4-speed runs good.
55 2 door post, gasser project
69 Cadillac ElDorado
69 4x4 suburban
59 ElCamino
Some mornings, it's just not worth chewing thru the leather straps"
stevo camaro is offline
post #2 of 5 (permalink) Old Jun 4th, 19, 07:03 PM
scblucam's Avatar
Re: BB lifter valley pan
If the lifters are correct they would be fed by the oil galleys having nothing to do with a valley pan.
68 302 M20 - 85 IROC Z
scblucam is offline
post #3 of 5 (permalink) Old Jun 4th, 19, 07:12 PM Thread Starter
Is it correct to say that the valley pan is designed just to keep heat away from the intake manifold?
69 4x4 suburban
59 ElCamino
post #4 of 5 (permalink) Old Jun 4th, 19, 07:22 PM
Beth
Yes you are correct.
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #5 of 5 (permalink) Old Jun 4th, 19, 07:24 PM Thread Starter
Then I think I'll install it.
69 4x4 suburban
59 ElCamino
