Fuel line from pump to carb - Team Camaro Tech
 9Likes
  • 1 Post By tp_smith
  • 1 Post By DOUG G
  • 1 Post By scblucam
  • 1 Post By Just 1 More
  • 1 Post By Shannon4570
  • 2 Post By flat tire
  • 1 Post By BOOGIES
post #1 of 10 (permalink) Old Jun 5th, 19, 02:08 PM Thread Starter
Guys - I'm looking to put in a braided fuel line with AN fittings. Can someone tell me exactly what I need in terms of fittings and line? It would be going from a standard mechanical fuel pump to the fuel filter (link below) Is there a kit out there? Already purchased the threaded in-line fuel filter from Summit.
Thanks,
https://www.summitracing.com/parts/sum-230100
1968 Convertible, 355 ci 400 hp Blueprint sbc engine, 600 cfm Edelbrock, Performer intake, 4L60E, 10 bolt, 3:08
Troutslayer is offline
post #2 of 10 (permalink) Old Jun 5th, 19, 02:56 PM
Patrick
Re: Fuel line from pump to carb
Wow, looks like the same filter Jegs sells.
You are using 6AN fittings on the filter so a 3/8" fuel line is needed. You will need two female 6AN fittings for the filter.
Decide which manufacturer you want to use for the fuel line and fittings. You might be able to mix and match different manufacturers fuel line and fittings but I would not take the chance. Choose the type of hose you want to use and then order the matching fittings.
Earl's makes hoses and fittings. Russel is another manufacturer. Download their catalogs. Use the catalog to match the correct flexible hose to the correct fittings for that particular hose. You might need some sort of adapter to convert from the AN fitting to the connection on the fuel pump. The connection to the old fuel line between the filter and gas tank might need another adapter. They are in the catalogs.
As the photo above shows, I used a hard line product called NiCopp. It is a viable alternative to flexible lines.
Troutslayer likes this.
Money can't buy you happiness but it can buy you car parts which is bout the same thang.
Patrick
tp_smith is offline
post #3 of 10 (permalink) Old Jun 5th, 19, 02:57 PM
Any local speed shops ? or even a Pep-boys ?
Easy enough to fab up, but you'll need to know what size fittings you'll need to make the fuel pump and carb (like a 1/4" NPT to -6 AN) then the size line you want/need along with fittings needed to connect.
-6 is 3/8" ….which is most likely what you'll need.
AN is measured in 1/16' 's just FYI if you didn't know.
68 Camaro~LSx ~all motor
post #4 of 10 (permalink) Old Jun 5th, 19, 06:12 PM
scblucam's Avatar
Get the proper tool for cutting the braided line. Tape the end before you cut just not too thick so you can twist the AN fitting onto the hose.
68 302 M20 - 85 IROC Z
scblucam is offline
post #5 of 10 (permalink) Old Jun 6th, 19, 06:20 AM
Frank
And if you have not already bought the hose and fittings, I highly recommend Hot Rod Fuel Hose, cheapest place i've found https://hotrodfuelhose.com/
'68 Camaro 454, 4sp
Just 1 More is offline
post #6 of 10 (permalink) Old Jun 6th, 19, 09:37 AM
Tim
Has anyone tried the cable cutters from HF for braided line? They are only $20 compared to the $60 -$90 for others and for such a limited use might be fine? I'm not a big fan of HF other than for disposable type tools but this might be one to look at considering a typical setup may only result in a handful of cuts.
https://www.harborfreight.com/28-inc...q=cable+cutter
1969 Camaro - a gift from the brother-in-law build thread
Shannon4570 is offline
post #7 of 10 (permalink) Old Jun 6th, 19, 10:06 AM
kevin
a cutoff wheel on a 4" grinder works wonders for braided line. as said just tape it before you cut
Chevy68 and Troutslayer like this.
flat tire is online now
post #8 of 10 (permalink) Old Jun 6th, 19, 12:35 PM
Frank
Can't imagine why they wouldn't be ok for limited use as long as that's all you use them for. I bought a set from Lowes and they work great
'68 Camaro 454, 4sp
post #9 of 10 (permalink) Old Jun 17th, 19, 10:12 AM Thread Starter
Thanks all. Great input and advice. Much appreciated.
post #10 of 10 (permalink) Old Aug 12th, 19, 09:29 PM
stan
If you have a compressor, you can buy the cheap cambel air cut off tool at Wally world and get the good wheels at depot or lowes and it works great,I've used it for stainless pipe,the cutting wheel is the key,and don't forget to tape first.
BOOGIES is offline
