1969 SBC - Changing Pulleys - Team Camaro Tech
post #1 of 9 (permalink) Old Jun 23rd, 19, 04:19 PM Thread Starter
CDB
Clifton
Installed Classic Auto Air AC, and I need to install the proper pulleys (original only a PS car). I'm ordering proper pulleys (crank, ps, and water pump). Can they be replaced while on the car? Should I order a harmonic dampener as well as replace that as well (No reason to think it's bad)?
1969 RS/SS 350 3.31 4 Speed (All Original)
CDB is offline
post #2 of 9 (permalink) Old Jun 23rd, 19, 08:11 PM
Chris
Re: 1969 SBC - Changing Pulleys
Yes, you should be able to replace them on the car. I'd verify the condition of your damper before I'd buy one. I had mine rebuilt several years ago by the Damper Doctor. The rubber on mine was shot so it was time.
https://www.damperdoctor.com/
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #3 of 9 (permalink) Old Jun 23rd, 19, 09:41 PM Thread Starter
CDB
Clifton
Thanks for the advice. Besides normal sockets and tools, all I need is a PS pulley tool from autozone, right? Any other abnormal tools?
CDB is offline
post #4 of 9 (permalink) Old Jun 24th, 19, 07:18 AM
Chris
Standard tools should cover it and a tool to remove the PS pulley if necessary. You should be able to disconnect and move the PS pump around a bit if necessary to get a puller in if necessary. If you do elect to remove the damper make sure to buy/rent a proper removal/installation tool. Never pound on the damper.
ctcz28 is offline
post #5 of 9 (permalink) Old Jun 26th, 19, 09:34 PM
Red face Re: 1969 SBC - Changing Pulleys
If you have an original power steering pump with the large nut on the end, you don't need a puller as it is keyed and will come right off.
TJS69 is offline
post #6 of 9 (permalink) Old Jun 29th, 19, 11:24 AM Thread Starter
CDB
Clifton
Whoops. Definitely have the old version with a nut on the end. Do I need a special tool for the woodruff key? Or do I just use a wrench to loosen the nut while using a second wrench to hold it in place?
If I only try and remove the nut, it spins the whole pulley.
CDB is offline
post #7 of 9 (permalink) Old Jun 29th, 19, 01:55 PM
I think I used an air impact to get mine off. Mine came off really easy, though. You may be able to keep it from turning with a belt on the pulley.
TJS69 is offline
post #8 of 9 (permalink) Old Jun 29th, 19, 02:20 PM Thread Starter
CDB
Clifton
Got it. Thanks. That was a pain.
CDB is offline
post #9 of 9 (permalink) Old Jun 29th, 19, 02:34 PM
Those strap wrenches come in handy for holding pulleys while you have a wrench on the nut.
SoCal805 is offline
