Lq4 - Team Camaro Tech
post #1 of 13 (permalink) Old Jun 25th, 19, 08:36 PM Thread Starter
Apprentice
Matt
Lq4
I have an lq4 gen 3 block bored .30, wiesco tru street pistons, nodular crank from summit racing, cnc ls 3 heads from summit racing. Can somebody recommend the remaining engine parts that i need to get the most bang for the buck. No power adders please. Thanks
Mhdsu is offline
post #2 of 13 (permalink) Old Jun 25th, 19, 08:42 PM
Vega$69's Avatar
Re: Lq4
Cam?
LS3 intake
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 13 (permalink) Old Jun 25th, 19, 08:51 PM Thread Starter
Apprentice
Matt
Some type of ls3 intake. Need help on rest of engine parts.
Mhdsu is offline
post #4 of 13 (permalink) Old Jun 26th, 19, 05:41 AM
Bill
Re: Lq4
What exactly are your plans for the engine ? Strictly street ? Strictly race ?? What kind of car, what trans, what gears etc etc etc etc. Camshaft is probably your most important decision and without knowing exactly what you are doing with the engine you rally cannot pick a cam.
What fuel injection and ignition do you plan on using ?
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #5 of 13 (permalink) Old Jun 26th, 19, 02:38 PM Thread Starter
Apprentice
Matt
Re: Lq4
Car will be pretty much street. Will have the prostreet look. Just asking to see if anyone can suggest cam, trans, and the rest of the parts for the engine.
Mhdsu is offline
post #6 of 13 (permalink) Old Jun 26th, 19, 02:52 PM
Re: Lq4
Carbed or injected
Power wanted
Gears/tire size
Auto/Manual/Overdrive trans
Will need your piston to valve clearance @ top dead center
What compression you have
68 Camaro~LSx ~all motor
post #7 of 13 (permalink) Old Jun 27th, 19, 09:33 AM Thread Starter
Apprentice
Matt
Re: Lq4
Injected, around 500 rwhp auto trans. Just wanting kind of a blue print on what parts I need to complete the engine.
Mhdsu is offline
post #8 of 13 (permalink) Old Jun 27th, 19, 09:35 AM Thread Starter
Apprentice
Matt
Re: Lq4
29 12.5 15 Hoosier pro street tires, Maybe 373 gears???
Mhdsu is offline
post #9 of 13 (permalink) Old Jun 27th, 19, 10:15 AM
Vega$69's Avatar
Re: Lq4
500 RWHP is hard to get NA with an LQ4 as you will need to build an engine that is close to 600 hp at the crank. At 30 over its a 370 ci engine. Will need approx 11:1 compression. The stock LS3 intake is best unless you run a big cowl hood and can go with a High ram intake. Will need a very aggressive cam which will affect street-ability with the auto trans. The correct TC will be critical.
Vega$69 is offline
post #10 of 13 (permalink) Old Jun 27th, 19, 08:02 PM
Re: Lq4
Stroker? I dont think he will get to 394 with just a bore.
3d cad is offline
post #11 of 13 (permalink) Old Jun 27th, 19, 08:17 PM
Vega$69's Avatar
Re: Lq4
Corrected. Only a 370 ci engine.
Vega$69 is offline
post #12 of 13 (permalink) Old Jun 28th, 19, 05:34 PM
Re: Lq4
OK, but will need to fly-cut pistons to fit the cam you'll need to make that power.....most likely
Piston to valve clearance is _____ ???
post #13 of 13 (permalink) Old Jun 28th, 19, 11:05 PM
Re: Lq4
How much of the rest of the engine do you have? Oil pump, pan, barbell, harness, controller, are the heads rectangular or cathedral, .. the list of what you havent mentioned is long. Automatic or manual? Go to Cam Motions web page and look at their Titan series of cams, read the application data and see where you fit in.
3d cad is offline
