Victor jr hood clearance - Team Camaro Tech
 1Likes
  • 1 Post By moncam
post #1 of 5 (permalink) Old Jun 26th, 19, 07:37 AM Thread Starter
Probationer
G
Hi all,
I have a couple of questions. I have a 1967 rs ss big block and a 1970 1/2 rs ss big block and I want to put Victor jr on both of them. On the '67 I want to use a drop base air filter, but on the '70 1/2 I don't mind running without a filter.
My question is will the manifold clear the stock '67 ss hood and stock '70 hood?
moncam is offline
post #2 of 5 (permalink) Old Jun 26th, 19, 09:07 AM
Re: Victor jr hood clearance
With a drop based air leaner you make up the added height of the Victor Junior manifold (you can find out how much by comparing a Performer Manifold to the Victor Jr as the Performer is the same size as the stock Chevy Winters high rise). Don't remember what it was but it was around three quarters of an inch from memory.
Since you are not running an air filter in the second generation it should clear. This assumes in both cases that the BBC was installed correctly.
Big Dave
Larger Dave is online now
post #3 of 5 (permalink) Old Jun 26th, 19, 10:06 AM Thread Starter
Probationer
G
Thanks Dave!
Yeah for the '67 I think I should be fine. I'm putting a 489 in it and making it look stock. 950cfm carb won't have the added height of a choke.
With the '70 im putting a holley 850cfm # 0-9380 on the Vic jr so with that one I may have to just buy it and try it to see how it goes
1967 Camaro RS SS 396
1970 Camaro RS SS 402
1970 Holden Monaro GTS 434
moncam is offline
post #4 of 5 (permalink) Old Jun 26th, 19, 10:31 PM
Gary
69Z28's Avatar
Originally Posted by moncam View Post
Hi all,
Is there much difference between the Team-G and the Victor Jr? I have a Team -G on a .060 402 in a 68 Firebird that had clearance issues even with the center bulge on the Firebird hood. I used a low filter base, but had to go even shorter on the filter. It was close but it worked. I mostly ran without as well. The Camaro hood being flatter then the Firebird hood may be the difference. Heck I thought I had a pic with the filter on but I don't sorry.
06A 1969 Camaro Z28 711 69 B Black Stripes Console w/tach and gauges
69Z28 is offline
post #5 of 5 (permalink) Old Jun 27th, 19, 10:01 AM Thread Starter
Probationer
G
I think the Team-G is slightly taller so I should be all good for the '67
Just the '70 im worried about now. It's hard to get the low profile 2" cowl hoods here in Australia we're stuck with the 2 3/4" cowl only here
69Z28 likes this.
moncam is offline
