Engine choice - Team Camaro Tech
 1Likes
post #1 of 16 (permalink) Old Jun 29th, 19, 11:44 AM Thread Starter
GCS
Greg
Engine choice
For building a street engine 350-400 hp range I have 2 short blocks available, both 4bolt main. Both rebuildable cores 1) 350 other 400. Is one better than the other. I’ve always used 350’s but wondering about the bigger cubic inches of the 400
GCS is offline
post #2 of 16 (permalink) Old Jun 29th, 19, 12:48 PM
Vega$69's Avatar
Re: Engine choice
400 is better hands down.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 16 (permalink) Old Jun 29th, 19, 12:50 PM
kevin
Re: Engine choice
if you want torque, build a 383
flat tire is offline
post #4 of 16 (permalink) Old Jun 29th, 19, 01:01 PM
Vega$69's Avatar
Re: Engine choice
400 is same stoke as 383 but with more cubes. So you’re gonna get more torque out of the 400
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #5 of 16 (permalink) Old Jun 29th, 19, 02:31 PM
Re: Engine choice
400 a factory 4-bolt or machined splayed 4-bolt ?
4-bolt 400 was said to be weaker than the 2-bolt due to meat in the web....I'm not an engineer, so
But, I'm sure with a little block filler, it will be more than fine at the power level you're wanting.
Talk to your machinist/builder
Now, in saying that, I would go 400 all day...
68 Camaro~LSx ~all motor
post #6 of 16 (permalink) Old Jun 29th, 19, 03:59 PM
Re: Engine choice
You are correct Doug. When the newer versions of the 400 were recast they had a thicker main web making the newer two bolt blocks stronger than the earlier four bolt main cap blocks.The '509 is supposed to be the strongest.
Another fun fact about 400 blocks is there is no core shift. With a 350 or any other previous SBC the individual cores were laid into the cope in pairs that could shift around. The 400 was a single core for all eight cylinders.
Big Dave
Larger Dave is offline
post #7 of 16 (permalink) Old Jun 29th, 19, 04:36 PM
Re: Engine choice
Thanks Dave, been a while
My old 406" had 350 rods, Eagle crank for a 400, and pistons that were for a ? 377 (de-stroked 400) and seen 7500-7800 for the norm at the track (400's aren't rpm motors )
Was low 11's in the 118-119 range.
post #8 of 16 (permalink) Old Jun 29th, 19, 10:58 PM
Darin
ilikeike's Avatar
I can’t really think of any reason to build a smaller cubic inch small block over a larger cubic inch one for a a normal type street hot rod.
400++. Go big.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #9 of 16 (permalink) Old Jul 1st, 19, 06:06 AM
Bill
Re: Engine choice
I seem to remember core shift being a problem on the sbc 400.
arocars is offline
post #10 of 16 (permalink) Old Jul 1st, 19, 07:17 AM
Re: Engine choice
For the street, build for torque - it pegs your Seat-O-Pants meter.
The energy used to move an object from a standstill.
Longer stroke, more torque.
You can go to Wallace Racing site and use their formulas for torque/HP as long as you know the weight of the Camaro.
Losing weight is free power, less weight, more acceleration.
Yes, I used a 350 2-bolt +0.020" overbore & PG to push a 2900 lb Camaro to 11.90/115 MPH in the qtr mile.
Doing a good job is like peeing in your dark pants … you get a warm feeling, but nobody notices
post #11 of 16 (permalink) Old Jul 1st, 19, 02:11 PM
Larry
Re: Engine choice
Getting 1hp per cubic inch is not difficult, so the 350 should easily do it.
On the other hand when you are searching for additional power in an engine adding cubic inches is usually the easiest and safest route to that end.
The 400 will get you to the top of your desired range pretty easily.
I can't complain, but sometimes I still do.
Larry Madsen is offline
post #12 of 16 (permalink) Old Jul 1st, 19, 03:44 PM
Re: Engine choice
When my original motor got sick I replaced it with the GM ZZ383/425hp. long block.
flat tire likes this.
Known to run with scissors....
__________
1969 Camaro Z/28 "clone", GMPP ZZ383, Autogear M22W, Moser 12bolt w/TruTrac 3:73.
Fred Mertz is offline
post #13 of 16 (permalink) Old Jul 2nd, 19, 08:41 AM Thread Starter
GCS
Greg
Kinda what I have in mind. Going forged flat top pistons, decent quality aluminum heads ( still investigating which ones) mild hyd roller cam setup. How about intake? Single or dual plane? Have brand new dual. Exhaust already on there, hooker ceramic coated headers with 21/2 “ all way to tailpipes. 3.73 posi diff. & 4speed M20 Plus misc. necessities.
GCS is offline
post #14 of 16 (permalink) Old Jul 2nd, 19, 08:51 AM
Ed
Re: Engine choice
Go 400. There's no substitute for cubic inches.
ZEN357 is offline
post #15 of 16 (permalink) Old Jul 3rd, 19, 06:23 PM
Probationer
Dean
Re: Engine choice
When I was 17, built a 400 for my 69 SS. Stock bore, stock heads, stock pistons, very mild over stock cam. Elderbrock intake with spread bore ?Holley. All I knew it was a small block...after the build, it wouldn’t start....no compression...lol yes used 350 rings. Tore it down in back of a pickup truck. Put it back together and installed in the car same day. I could take off in 3 rd gear and smoke the tires. It lasted until I sold it 4 years later. Had many SB since. It was the most fun I ever had with a camaro. They are factory balanced as well..least externally. You will be pleasantly surprised by the extra performance.
DeanZ10 is offline
