Water pump ID - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 2nd, 19, 08:06 PM Thread Starter
Pat
Question Water pump ID
My 68 was overheating, so I replaced the t-stat and the idiot light sender...but the light still came on.
Next up is the water pump. I ordered one for a 68 camaro 350. When I went to install it tonight, I discovered the mounting bosses I need for the alternator werenít there.
The engine is a CKL code 1973 350, but as itís a transplant, I have no idea what the water pump application was originally.
Iíd like to keep the existing alternator bracket setup (non-original.) That requires two mount points on the passenger side, and one at the top.
Anyone know what application I should ask for at the auto parts place?
Pat - 68 Camaro Coupe -
patman2 is offline
post #2 of 5 (permalink) Old Jul 2nd, 19, 08:21 PM
Jeff
Re: Water pump ID
It looks like a long water pump mounted in the picture. Order one for the 1969 or later 350 engine.
Thanks,
Jeff
1968 Camaro
Chevy68 is offline
post #3 of 5 (permalink) Old Jul 2nd, 19, 08:22 PM
Beth
Re: Water pump ID
Before 1969, Camaros had "short" water pumps. They switched to the long pump in 69 and the alternator moved from the driver's side to the passenger side.
I guess they sold you a "short" water pump for a 1968 Camaro; but you need a "long" water pump for a 1973 350 engine.
Just tell them you need a water pump for a 1969 Camaro and it should look like the one that's on your 1973 engine.
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #4 of 5 (permalink) Old Jul 2nd, 19, 09:21 PM
scblucam's Avatar
Re: Water pump ID
Is it aluminum or just iron un-rusted and unfinished? If aluminum have it rebuilt.
68 302 M20 - 85 IROC Z
scblucam is offline
post #5 of 5 (permalink) Old Jul 2nd, 19, 09:57 PM Thread Starter
Pat
Re: Water pump ID
Thanks everyone! Always fun guessing what stuff POís installed. Iíll hit NAPA tomorrow. Thereís a show Saturday that Iíd like to attend, so having the current one rebuilt isnít likely.
Fingers crossed this fixes the problem. I have an original shroud, and a mechanical fan, but the radiator is only 1 core. That may be next to get swapped out. It was only 70* or so outside on the last temp light. Iím a little nervous itís a crack, but the oil and plugs looked ok.
patman2 is offline
