Pro Comp products?? - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 11th, 19, 11:45 AM Thread Starter
Pro Comp products??
I’ve been seeing a lot of pro comp products out there lately. Aluminum BBC heads, Stroker Kits, etc. seem to be very aggressively priced!
Anyone out there have any first hand experiment with this manufactures products?
Thank you
Camarocarter is offline
post #2 of 3 (permalink) Old Jul 11th, 19, 11:52 AM
Re: Pro Comp products??
Thank you
A lot of people have experience with them. Some good opinions and some bad. Do a search and you'll see it discussed at length. I almost went with a set of heads, but I didn't in the end. I just didn't get the warm and fuzzy.
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #3 of 3 (permalink) Old Jul 11th, 19, 12:22 PM
Rufas
Pro-Comp Electronics Company in Ontario Cal., and Australia, ignition, intake system, aluminum heads (only ONE design, a modified stock head), too good to be true pricing, RUN AS FAST AS YOU CAN THE OTHER WAY.
Pro-Comp heads made in the U.S.A. (NOT Pro-Comp Electronics in So. Cal), should be OK.
dave ray is offline
