Fuel line routing issue (like L78) - Team Camaro Tech
 6Likes
post #1 of 16 (permalink) Old Sep 9th, 19, 06:36 AM Thread Starter
I'm pretty aggravated with myself right now. I ordered the L78 pre-bent lines for the fuel feed from the pump to the carb. Z28 lines showed up... So I figured I'd just bend the long one because it's pretty straight. That's when I noticed the feeds to the float bowls from the Y block are 5/16". Bah... I wanted the basically stock look, but I want to run 3/8" the whole way. 5/16" would probably be fine for the two branches, but then I'd need different adapters also.
Does anyone know of a stock looking brass fuel line Y block that is 3/8" in and out? For now I'm having to run a Mallory aluminum Y block and I'm custom bending all three lines.
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #2 of 16 (permalink) Old Sep 9th, 19, 07:57 AM
Rick
Re: Fuel line routing issue (like L78)
COPOís ran 3/8 to two 5/16. Should be no problem.
Thatís what I run with no issues.
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #3 of 16 (permalink) Old Sep 9th, 19, 07:58 AM
kevin
1966-1972 Corvette Fuel Distributor "Y" Block
ECKLERS
Save
1966-1972 (C2, C3) Fuel Distributor "Y" Block
Part #:
25-122346-1
Replacement for OE #: 3886153
Price:
$21.99 ea
flat tire is offline
post #4 of 16 (permalink) Old Sep 9th, 19, 08:38 AM Thread Starter
Part #:
25-122346-1
Price:
$21.99 ea
Thanks Kevin. That's the same spec as what I have though. 3/8" inlet with two 5/16" outlets. I want 3/8" for all three.
Rick, I hear what you're saying and you're probably right, but I'm running ~550 hp/550 ftlb right now which will increase over time. Our specs are pretty close by the looks of it, but I'd feel more comfortable with 3/8" all the way around. That's why basic fuel logs are generally all 3/8". I run my car pretty hard when I'm playing. I'll end up at the 1/4 mile with it.
Semper Fi!
HawkX66 is offline
post #5 of 16 (permalink) Old Sep 9th, 19, 09:29 AM
Dave, Parker probably makes the fitting. You might find a Parker online catalog.
my 67' build thread:
allanjs is offline
post #6 of 16 (permalink) Old Sep 9th, 19, 10:30 AM Thread Starter
Thanks Al. I'll check them out.
Semper Fi!
HawkX66 is offline
post #7 of 16 (permalink) Old Sep 9th, 19, 11:44 AM
I had a problem with the 5/16 fittings weaking. Both at the float and at the y-block. I was able to get 3/8's lines and y-block from Steve's Camaro's in San Bruno. Steve's is no longer in business but the 3/8 setup must be out there. It's a common problem with repo parts.
HawkX66 likes this.
Known to run with scissors....
__________
1969 Camaro Z/28 "clone", GMPP ZZ383, Autogear M22W, Moser 12bolt w/TruTrac 3:73.
Fred Mertz is offline
post #8 of 16 (permalink) Old Sep 9th, 19, 03:17 PM
Morgan
I have both the 3/8 and the 5/16, no difference. I use the5/16 on the original carb and the 3/8 on the other 2
I found the 3/8 on eBay some time ago, but could not find them the last time I looked
HawkX66 likes this.
69 Copo 9560 ZL-1 automatic [email protected], 1.95 on f70-14 polyglas F.AS.T. Race June 2016
69 Copo 9560 ZL-1 4spd [email protected] 1.93 60ft on F70/14
PSMCDR 2014
71LS6 vette [email protected] PSMCDR 2012 SOLD
1971ls6 is offline
post #9 of 16 (permalink) Old Sep 9th, 19, 03:55 PM
https://www.ss396.com/camaro/RSBB06.html
https://www.getdiscbrakes.com/rsbb06
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #10 of 16 (permalink) Old Sep 10th, 19, 06:19 AM Thread Starter
Those are the stock specs 3/8" to 5/16".
Semper Fi!
HawkX66 is offline
post #11 of 16 (permalink) Old Sep 10th, 19, 06:32 AM
Says 3/8x3/8x3/8 which means 3/8 on all ports. At least that is my understanding. Suit yourself...
dhutton is offline
post #12 of 16 (permalink) Old Sep 10th, 19, 06:54 AM
Iím a hack but all these ports look the same size to me....
https://www.jegs.com/i/Right-Stuff/965/RSBB06/10002/-1
HawkX66 likes this.
dhutton is offline
post #13 of 16 (permalink) Old Sep 10th, 19, 07:37 AM Thread Starter
My apologies Don. You nailed it! I saw it said for stock set up and thought it was the same one I'd been seeing. Thanks!
allanjs likes this.
Semper Fi!
HawkX66 is offline
post #14 of 16 (permalink) Old Sep 17th, 19, 11:53 AM Thread Starter
Thanks again to Don for pointing me to the correct fitting. Here is how it turned out.
dhutton and allanjs like this.
Semper Fi!
HawkX66 is offline
post #15 of 16 (permalink) Old Sep 17th, 19, 06:01 PM
Morgan
At onetime I found a guy on eBay that sold the 3/8x3/8x3/8 with the lines to the carb as well. I cannot find anyone that has these pre bent, anybody know where to find them?
PSMCDR 2014
1971ls6 is offline
