First oil change - Team Camaro Tech
 9Likes
  • 1 Post By SoCal805
  • 4 Post By BillK
  • 3 Post By rp930
  • 1 Post By ctcz28
post #1 of 12 (permalink) Old Oct 8th, 19, 09:50 AM Thread Starter
Probationer
First oil change
Okay, another thing I *need* to do is give my Camaro an oil change. It's a 69 with a 302 in it, and I have no idea how long it's been since the oil was changed, atleast 5 years (of which it's been sitting and limited in having been driven), and the person who knows what's in it passed away 2 years ago. So I'm working blind here. Any suggestions on oil, filter and any additives would be super helpful. Thanks!
Mythodica is offline
post #2 of 12 (permalink) Old Oct 8th, 19, 09:54 AM
Re: First oil change
Hemmings 10W30 Motor Oil. AC/Delco filter.
post #3 of 12 (permalink) Old Oct 8th, 19, 10:43 AM
kevin
any 10w30 oil. fram saved my engine when the cam went south . that is what I suggest. just my 2 cents or wix
flat tire is offline
post #4 of 12 (permalink) Old Oct 8th, 19, 11:56 AM
Any 10-30 brand oil. I prefer WIX filters. The NAPA "gold" filters are made by WIX.
IDK what chain auto part stores you have in your area but O'Rielys here carry WIX. You can buy any brand you want. Most chain auto part stores websites you can "enter your vehicle" (year, make & model) so when you search for a part, like oil filter, all the brands they have available that are applicable to your car will show up. Once you find part #'s/brand you can order them from Amazon, including any oil type, if you prefer to shop that way
ctcz28 likes this.
SoCal805 is offline
post #5 of 12 (permalink) Old Oct 8th, 19, 01:48 PM
Bill
You need to use an oil that has the proper additives for the old style flat tappet camshaft. I would use 10W30 Valvoline Racing or one of the "Hot rod" oils that are available. Make sure that they mention "zinc" or ZDDP on the label. Wix or AC Delco filter will work fine.
HawkX66, rp930, boyd66k20 and 1 others like this.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #6 of 12 (permalink) Old Oct 8th, 19, 02:55 PM
Rick
Valvoline VR1. 10W30 conventional. Wix. X2
Vega$69, boyd66k20 and Just 1 More like this.
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #7 of 12 (permalink) Old Oct 8th, 19, 03:02 PM
^^, Op. I missed the 302 part. Your brake thread noted drum brakes, which if true than the car would not have been a Z28 with 302 motor. However the previous owner may have put in a 302 flat tappet motor
Valvoline VR1 or Joe Gibbs Racing oil have high Zinc content which you want for a flat tappet cam motor....assuming that is what you have
SoCal805 is offline
post #8 of 12 (permalink) Old Oct 9th, 19, 07:57 AM
Chris
Valvoline VR-1. There are many good high ZDDP oils, but the Valvoline is probably most widely available off the shelf at your local store which is why I recommend it. I use VR-1 in my flat tappet engine with no issues. Quality WIX filter (WIX makes Napa Gold filters too). Here is a list of oils many here have used and the Zn and P levels.
Name:	Oil Zn-P Levels.jpg
Just 1 More likes this.
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #9 of 12 (permalink) Old Oct 9th, 19, 08:24 PM
Vega$69's Avatar
Valvoline VR-1 and Wix filter.
Fram. No way Jose
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #10 of 12 (permalink) Old Oct 17th, 19, 01:10 PM
Wiley E. Coyote
w/vegas, not pricy and works great.
If you are a synthetic guy 15/50 has the good stuff in it for FT engines I think its a waste though.
cv67 is offline
post #11 of 12 (permalink) Old Oct 18th, 19, 06:56 AM
I bought a case of Wix filters for my 69 and I run Brad Penn 10w30. Everyone has their favorite oil, but I would definitely not cheap out with a flat tappet cam. You will pay for it with modern oils. Honestly, everyone complains about Fram, but I used to run them in a lot of vehicles and never had a problem.
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #12 of 12 (permalink) Old Oct 18th, 19, 07:30 AM
Probationer
if its flat tappet then Brad Penn oil. I usually use 5W30.
railbrd9 is offline
