Engine Oil for Solid roller cams in 2019 - Team Camaro Tech
 3Likes
post #1 of 16 (permalink) Old Oct 23rd, 19, 05:05 PM Thread Starter
RAFAEL
Hello guys ,
I know there have been countless debates on this subject. And I've been reading them for all for the past 4 days.
But the problem is they are all old and as you all know, oil quality seems to degrade more and more every year.
So I want to know what people are using in 2019.
I currently use VR 20w50 and I'm about to put some winter oil in it to see if I can get a extra 3-4 weeks of driving. Thinking of 10w30 or 10w40
I have a SBC 383 with a .640 lift solid roller cam.
Sorry for the question I'm just really curious. I'm also curios about how many of you are using 15w40 Diesel oils on SOLID roller cams.
Please be specific. Thanks!!!!
Last edited by LAZR_GUIRA; Oct 23rd, 19 at 05:06 PM. Reason: forgot to add the year in the tilte
LAZR_GUIRA is offline
post #2 of 16 (permalink) Old Oct 23rd, 19, 06:00 PM
Garth
Re: Engine Oil for Solid roller cams in 2019
You donít need to worry about zinc with a roller cam. Also, the lifters probably have a spec for oil weight. Itís usually 10w30 or 40. Bearing clearance will determine what you need too.
I use Rotella in older flat tappet engines with stock weight valve springs. VR1 in anything with heavy springs and flat tappet.
1969 Camaro SS 350 LeMans Blue
2015 Z/28 - Red
2 x 1967 R/Tís
1977 Power Wagon
69L48Z27 is offline
post #3 of 16 (permalink) Old Oct 23rd, 19, 07:02 PM
Morgan
VR1 from menards is $4.99 a quart everyday, buy it when they run the 11% rebate.
I run a 20/50 all year. When itís real cold, I bought an oil pan heater and turn it on an hour before I start it, never a problem
69 Copo 9560 ZL-1 automatic [email protected], 1.95 on f70-14 polyglas F.AS.T. Race June 2016
69 Copo 9560 ZL-1 4spd [email protected] 1.93 60ft on F70/14
PSMCDR 2014
71LS6 vette [email protected] PSMCDR 2012 SOLD
1971ls6 is offline
post #4 of 16 (permalink) Old Oct 23rd, 19, 07:25 PM
Wiley E. Coyote
The oils are fine its the quality of cam cores and lifters thats poor. If you have a steel one you may be fine.
No need to run superheavy oils either thats kinda 70s thinking. 10/30 is just fine for more these days
cv67 is offline
post #5 of 16 (permalink) Old Oct 23rd, 19, 10:42 PM
Alex
As mentioned, run the proper weight for your bearing clearances.
I run only Redline oil, it's made right here in So Cal.
1969 Pontiac Firebird
w/BP 461ci stroker kit, 670 heads & XE274H cam. Primer black w/black interior.
1992 Pontiac Trans Am GTA w/SLP Performance Package. Dark Jade Grey Metallic, grey leather, T-Tops.
anguilla1980 is offline
post #6 of 16 (permalink) Old Oct 24th, 19, 07:49 AM Thread Starter
RAFAEL
Thanks guys for all the great tips and responses.
I like that block heater Idea for the winter.
post #7 of 16 (permalink) Old Oct 25th, 19, 05:20 AM
Greg
pittpens24's Avatar
This came recommended by my engine builder. Expensive but zero issues with my solid roller thus far.
https://inrccca.org/product/classic-car-motor-oil/
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #8 of 16 (permalink) Old Nov 9th, 19, 09:30 PM
Randy
I have an oil question for you guys. what type of oil do you recommend? Synthetic or non-synthetic?
randydray is offline
post #9 of 16 (permalink) Old Nov 10th, 19, 03:16 PM
Everyone will have their own preference. I just use conventional 10-30. Valvoline
69Z28 and randydray like this.
SoCal805 is offline
post #10 of 16 (permalink) Old Nov 11th, 19, 05:57 PM
Beth
Friction is a lot less with synthetics, so it makes no sense to me to use non-synthetic if you don't have to worry about a flat tappet cam.
Some hydraulic roller lifters have very tight tolerances and don't play well with high viscosity oils.
randydray likes this.
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #11 of 16 (permalink) Old Nov 11th, 19, 06:32 PM
I have been using Mobil 1 Turbo Diesel Truck 5W-40 synthetic motor oil in my 383. Oil pressure is great when cold and hot. I have used it for years in non GM, really high performance turbo (gas)builds and road race track cars. It is pretty cheap at Walmart.,
1968 camaro
EVL SS is offline
post #12 of 16 (permalink) Old Nov 11th, 19, 06:38 PM
Vega$69's Avatar
I use Mobile 1 in my LS swap builds and Valvoline VR1 or Schaffers for the rest. https://www.schaefferoil.com/
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #13 of 16 (permalink) Old Nov 11th, 19, 09:20 PM
randy
My initial response was for a stock motor build, which is what I have and use conventional 10-30.
Post what your motor/build is because "one size fits all" does not apply to oil type/viscosity. Solid or hydraulic cam and or lifters, wider bearing clearances are examples of different needs. Example, my H/C 383 hydraulic roller HV oil pump in another car uses 20-50 Conventional
SoCal805 is offline
post #14 of 16 (permalink) Old Nov 12th, 19, 04:27 AM
george
Big fan of the Vr1 oil.I use 10-30 myself.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #15 of 16 (permalink) Old Nov 12th, 19, 02:10 PM
Lorne
I recently switched my solid lifter cars to Amzoil 10w30 Z Rod as it exceeds the zinc level recommended by GM. I don't have any problems to discuss which is a good sign, other than it is on the upper end of the price scale but also I don't get many miles on those vehicles.
hiperf406 is offline
