Wondering what people's thoughts are on these distributors. It's the mallory unilite with vac advance. I've used one in the 327 for 22 years and haven't had any problems with it.
Running another one just like it in the 427 I just installed. In trying to dial in the 427, ( timing and carb adjustments), I set my initial to 18*. Motor likes it. But after I plug in my vac advance, ( to constant vac), I get a reading of 45*. At 2200 + it runs up to 55. Not sure if these dist. have an adjustment inside or not. And, I am using a dial timing light. LOL
I've been reading on how many guy's hate the dial timing lights. But hell, how would I have ever seen 55* without it. LOL
Anyone well versed on the mallory?
Sounds like you need to install a positive stop on your vacuum advance can to keep your total advance within more reasonable limits; 45 sounds high. Search for postings by Dave Ray concerning distributors, vacuum advance and dial-back timing lights.
I looked inside this unit and there's no mechanical advance at all. No springs. Just the vac. rod. Someone said I shouldn't disconnect the vac advance while timing this type of dist. Time it plugged in. I'll give that a try and see what happens.
Without any centrifugal advance how is it gaining 10* at 2200+ rpm? Is this an older unit
somebody could have messed with? If you set the timing with vac advance connected what
are you going to set at? If you set at or around 18* your true initial will be badly retarded
won't it? Something just seems off to me.
No, I pulled the rotor and trigger plate too. There's nothing else in there but the module and vac advance rod attached to the plate. Plate moves freely. It was new in the box. I'd say it's about 15 years old now. Looks like this dist. gets all it's advance from vac.
Talking to a guy today, who's a mechanic by trade, say's I need to leave the vac hooked up to get the initial on this type. Really? I've never done that before.
I'm going to look at the one in the 327 tomorrow. There's probably a difference between the 2 somehow.
Sounds to me like it's only going to work correctly with ported vacuum then. I know
very little about the unilite but I do know they've gone though variations over the years.
Like I said, it’s been a long time, but I remember removing the C clip on the vac advance and removing the advance plate to get to the springs underneath. They’re dow deep in the body. It sucked. I had extre C clips cause I’d loose them.
Mechanical advance is under the plate. You have to disassemble the dizzy to get to it. remove gear and pull the shaft. Go to the holly website click Mallory Unilite and download the manual.
SteveO I had that same dist. in my 69. Here are the issues I had with mine. Previous owner had put the wires to close to the shaft, it rubbed through and grounded them to the shaft intermittently. Car would occasionally buck and snort and stop cold turkey. Then start up again.That sucks. I took it apart, it was dirty, cleaned it up and bought a new module kit and got the Vac arm put back onto the pin again and then things ran much better
Yeah Jim, I had a problem with that trigger plate rubbing thru the red power wire on the RS 20 years ago. Fixed that and haven't had a problem with it since.
Looking at your pics, the plate that moves in the dist. looks pretty flat on the aluminum housing. Looking at the holes drilled in it, all I see is the housing. And there's springs under that? Doesn't look to me like there would be anything under it.
Wish you had a pic with the plate out. LOL
I can positively tell you that I had a mallery unilite in the 80s. You have to gut it to get to the springs.
Maybe you have a different model. But where are your springs weights... ?
Take all the screws out, lossen the allens on the side and look in the bottom.
SteveO I never got down into the bowels of the bowl but Im guessing that's where the springs are. I found a few more pics from my disassemble that I did. Not sure what caused that reddish color dust/crap under all the working parts, maybe a lube but it sure cleaned up nicely. It appears there was a 47 black number on the base of that area but it washed off when I cleaned all that crud out of there. You can see it in one of the pics. I have no clue where the springs are weights are at all. It all seems to be a cast alum piece with no access other than the small plug that screws into the side of the base of the bowl. Weird.
Okay, the part # for this dist. is 4748201. I think I'm going to need to change the vac. canister. The mechanical is advancing it 14* at 2300 rpm. The issue I think , maybe, is that after going from 18* initial, it jumps to 45* as soon as I plug in the vac. And after taking the RPM's to 2300 ish, it's stops at 59*
I will say this though, The motor seems happy with it. It fires right up, it idles fine at 1000 RPM, ( not bad given it's cam,) and the car is accelerating well. I seem to have taken the off idle stumble out of the carb. I do need to drive it around more, the registration will happen today. I've been blasting it down the road a half mile and back with no tags trying to dial it in. It runs cool, ( we're still 70 over here). But, I do need to cruise it more that a mile at a time to really tell what's going on I suppose.
I still haven't looked up this dist, number. I'll be doing that now.
Maybe I'm too concerned with nothing. LOL
Steve, I looked up that distributor at Summit. Their pic shows a hex shaped vac can.
I think those are adjustable by inserting a hex key wrench though the tube on the can.
From what I've gathered on this post you're getting acceptable mechanical advance but
way too much from the vac can. You may only need to adjust the vacuum.
So I download the information and print out the info on this dist. As I'm reading through it, it says to connect the vacuum advance to a PORTED outlet on the carb.
I've read plenty of discussion on this. The consensus is NEVER go ported vac. Wonder why they're telling people to do this? Are they assuming we're all using them in smogged out motors with 125 H.P.? LOL Things that make you go Hmmmmm.
Okay, it is an adjustable vacuum advance. I got as far as finding the right allen and getting it to turn. Then the phone rang. So, hopefully today I can make the adjustment. Not sure which way to turn it or how many degrees it will swing yet. Maybe someone knows? I can figure it out through trial and error.
Put the tags on it monday, so looking at the weather, I have this weekend before we get hit with snow possibly. Dammit! LOL
Unilite distributor.......brings me back to Super Shops where that was one of my first performance purchases. Was pretty temperamental so I pulled it out after many attempts and went back to stock. If you can make that work that is an awesome piece of the 80's!!! Would love to have mine back know that I know more and am much more patient.
Related Threads
Team Camaro Tech
2.4M posts
82.8K members
Since 1998
