Who's got the H.P. calculator? - Team Camaro Tech
post #1 of 7 (permalink) Old Nov 12th, 19, 09:17 PM Thread Starter
stevo camaro's Avatar
Question Who's got the H.P. calculator?
Just wanted some opinions I guess on my combo here. And if anyone has a H.P. calculator that would be cool. So, here's what I ended up with.
427 cu.
454 block .30 over
steel 427 crank ( same as a 396 crank)
G.M. rods
speed pro pistons, closed chamber
9.8:1 compression
Bullet racing cam, part no. 502000 Hyd. roller
Dur. at .50 intake 230. Exhaust 240.
lobe lift intake & exhaust .3533
Lobe separation 110, degreed to 106
Duration at .006, Intake 284 exhaust 295
Gross valve lift .601 intake & exhaust
Bullet roller lifters
Cloyes double roller timing chain
Closed chamber iron oval port heads, 2.19 intake 1.88 exhaust. Heads ported and polished
Wieand single 4 BBl tunnel ram
Demon 850 mechanical secondaries, 50cc primary pump, 30cc secondary pump, squirters are 31's
Mallory unilite dist.
Dougs headers, 1 1/2" primary tubes, 3" collector
electric fans
3000 stall converter
TH-400
67 RS 327, 4-speed, posi, done.
67 Modified, 454, TH-400, posi, under construction.
67 SS 396, 4-speed, basket case.
72 RS, sitting, partially done.
55 210 post, 2 door, 327 4-speed runs good.
55 2 door post, gasser project
69 Cadillac ElDorado
69 4x4 suburban
59 ElCamino
Some mornings, it's just not worth chewing thru the leather straps"
stevo camaro is offline
post #2 of 7 (permalink) Old Nov 14th, 19, 05:51 PM Thread Starter
Re: Who's got the H.P. calculator?
Allrighty then. Guess there aren't any takers. LOL
69 4x4 suburban
59 ElCamino
post #3 of 7 (permalink) Old Nov 15th, 19, 07:23 AM
Try Wallace Racing.
Wallace Racing - Automotive Calculators
post #4 of 7 (permalink) Old Nov 15th, 19, 09:22 AM
Darin
ilikeike's Avatar
Just get one.
https://www.summitracing.com/search/...puter-software
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is online now
post #5 of 7 (permalink) Old Nov 15th, 19, 03:43 PM
427 cu.
454 block .30 over
G.M. rods
9.8:1 compression
electric fans
TH-400
I see some stuff that don't make sense to me...
427 cu.
454 block .30 over..... .030 over 454 isn't a 427 (427 .030 over is 439 and a 454 .030 over is 460)
1 1/2" primary tubes, 3" collector......1 1/2" primaries....on a BBC ????
68 Camaro~LSx ~all motor
post #6 of 7 (permalink) Old Nov 16th, 19, 05:27 AM
Beth
427 cu.
454 block .30 over
G.M. rods
9.8:1 compression
electric fans
TH-400
For a 433 cu in engine, I would guess 475 hp with that cam. The closed chamber heads will hurt it a small amount.
A 750 carb would probably help it down low and not hurt the top end.
I think your header specs are a misprint. Probably 1-3/4" X 3" collector
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #7 of 7 (permalink) Old Nov 18th, 19, 07:47 AM Thread Starter
Correct Beth That was a misprint. The headers are 1-3/4"
Okay Doug, it's a 439. LOL
I was thinking it was between 450 and 500 H.P..
Just wondering what others thought.
69 4x4 suburban
59 ElCamino
