Breathers - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 9th, 19, 11:38 AM Thread Starter
Randy Brutout
Randy Brutout's Avatar
Breathers
Gentlemen,
I have the car listed below with a 396 big block. My concern is with breathers. Originally when I bought the car it had a positive crankcase ventilation (PCV) on the right side of the engine going to the carburetor and a breather on the left. The engine seemed to be pushing a great amount of blowby out of the breather on the left side. So, I went out and bought two breathers and installed them both doing away with the PCV valve. But now itís like puff the magic dragon, I mean there is a lot of blowby coming out both breathers. Is this normal or do I have problems?
Thank you in advance for your comments.
1968 Camaro Super Sport, 396ci, Holley 600, Edelbrock Performer 2.0, Accel HEI, Muncie 4-speed, Hurst, 12-bolt posi 355s, Flow Master.
Randy Brutout is offline
post #2 of 5 (permalink) Old Dec 9th, 19, 12:10 PM
Re: Breathers
You should be running a PCV system and yes it sounds like you have problems. As bad as
your description sounds I would do a compression check to start.
my 67' build thread:
allanjs is online now
post #3 of 5 (permalink) Old Dec 9th, 19, 12:38 PM
Darin
ilikeike's Avatar
Re: Breathers
That much blow-by seems a bit excessive.
Time for a compression check and or leak down test.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #4 of 5 (permalink) Old Dec 9th, 19, 12:41 PM
Vega$69's Avatar
Re: Breathers
Excessive blow by.
Definitely time to think about a re-build.
Vega$69 is offline
post #5 of 5 (permalink) Old Dec 9th, 19, 05:29 PM
Re: Breathers
Yes, too much blow-by - leak test would show how well, or bad, the rings are sealing.
Also, an aggressive camshaft will produce less vacuum from the manifold.
The proper set-up is shown below.
